Why this paradox in calculating eigen values for T*T ?
  • Context: Graduate
  • Thread starter Thread starter vish_maths
    Eigen values Paradox
The discussion revolves around the calculation of eigenvalues for the operator T*T, where T is an operator on a vector space V and T* is its adjoint. Participants explore the implications of the eigenvalues of T on those of T*T, questioning the validity of certain assumptions and mathematical steps involved in the argument.
  • One participant proposes that if λ is an eigenvalue of T, then T*T has an eigenvalue |λ|² for the same eigenvector v, based on inner product relationships.
  • Another participant challenges this claim, arguing that the eigenvectors of a matrix and its adjoint are generally different, and thus the assumption that they are the same is flawed.
  • Concerns are raised about the validity of the argument that implies T*T v = |λ|² v, with one participant noting that the proof seems incomplete and potentially leads to incorrect conclusions.
  • Some participants discuss the implications of the inner product and the conditions under which certain equalities hold, suggesting that the conclusions drawn may only apply to specific vectors rather than all vectors in V.
  • There is a mention of the need for a more general proof that applies to all vectors in V, rather than just eigenvectors.
  • Participants express confusion regarding notation and terminology, particularly around inner products and adjoint operators, indicating a need for clarification in mathematical expressions.
Participants do not reach a consensus on the validity of the initial claim regarding eigenvalues and eigenvectors. Multiple competing views remain, particularly concerning the assumptions made about the relationship between T and T* and the implications of the inner product calculations.
Some participants note that the argument relies on specific assumptions about the vectors involved, and there are unresolved questions about the general applicability of the conclusions drawn. The discussion highlights the importance of rigor in mathematical proofs and the need to consider all vectors in the vector space.
vish_maths
Let T be an operator on the vector space V and let λ1, ... , λn be it's eigen values including multiplicity .
Lets find the eigen values for the operator T*T then ( where T* refers to the adjoint operator . <u,v> denotes inner product of u and v )
< Tv , Tv > = < λv, λv >
= λλ° < v , v >
= |λ|2 < v , v>
( where λ° is the conjugate of λ . )
=> <T*T v, v> = < |λ|2 v, v >
=> T*T has an eigen value |λ|2 for the same eigen vector v which T possesses.
This can be inferred because :
Suppose f is a linear functional on V . Then there is a unique vector v in V such that f(u) =<u,v> for all u in V.
( A linear functional on V is a linear map from V to the scalars F , As sheldon axler pg 117 says it ) The above argument must imply then that : T*T v = |λ|2 v ( Doesn't this imply v is an eigen vector of T*T ? )
now, let's consider a matrix $$M(T) = \begin{bmatrix}
1 & 3 \\
0 & 2
\end{bmatrix}$$
[ 3 1 ]T is clearly an eigen vector with eigen value = 2 .
(T* T ) =\begin{bmatrix} 1 & 0 \\ 3 & 2 \end{bmatrix} multiplied by \begin{bmatrix}
1 & 3 \\
0 & 2
\end{bmatrix}$$
= \begin{bmatrix}
1 & 3 \\
3 & 13
\end{bmatrix}$$
M(T* T ) upon multiplication with [ 3 1 ]T should produce a vector equal to
4 [ 3 1 ]T
however , \begin{bmatrix}
1 & 3 \\
3 & 13
\end{bmatrix} multiplied by [ 3 1 ]T = [ 6 22 ]T .
Can you please advise why this paradox exists ? Am i making a mistake somewhere ?
Thanks
I don't understand the bra-ket notation, but I think
is wrong.
The eigenvectors of a matrix and its (conjugate) transpose are different in general. Your proof seems to assume they are the same. If ##Tx = \lambda x##, then ##x^*T^* = \lambda^* x^*##, but that doesn't make ##x^*## a (right) eigenvector of ##T^*##. (It is a left eigenvector of ##T^*##, of course).
There's no bra-ket notation there, just inner products, absolute values, and the definition of the adjoint operator.
= λλ° < v , v >
= |λ|2 < v , v>
Why would ##\langle T^*Tv,v\rangle=\langle|\lambda|^2v,v\rangle## imply that ##T^*Tv=|\lambda|^2 v##?
I see that you tried to prove this, but the argument doesn't seem to make sense. There appears to be something missing from it as well. f(u)= what? Did you mean f(u)=v for all u? That actually implies that v=0.
Suppose f is a linear functional on V . Then there is a unique vector v in V such that f(u) = for all u in V.
Note that if we let w be any vector that's orthogonal to v, we have ##\langle T^*Tv,v\rangle =\langle T^*Tv+w,v\rangle##.
is wrong.
Thanks. <u,v> as fredrik pointed refers to the inner product of u and v . I get your argument regarding the adjoint operation.
Hi Fredrik,
Thanks for the answer. i have corrected it in the main thread , f(u) = <u,v> for all u in V.
I think the equation < Tx , y > = < z, y > => Tx = z if and only if < Tx , y > = < z, y > is valid for all y in V. ( w[itex]\in[/itex] V ) .
Lets consider the more general case of < w , y > = < z , y > , then w = z if and only if this relation is valid for all y [itex]\in[/itex] V.
Proof : Suppose there exists an another different quantity w≠z | < w , y > = < z , y >
Then : < w - z, y > = 0 for all y [itex]\in[/itex] V .
=> when y = w - z , then :
<w-z,w-z> = 0 => w = z .
<T*T v, v> = < |λ|2v, v > -------- (1)
=> I guess , T*T has an eigen value |λ|2 for the same eigen vector v which T possesses , if and only if (1) is valid for ALL v [itex]\in[/itex] V .
If it holds for all v, I think the correct conclusion is that T*T is equal to ##|\lambda|^2I## where I is the identity operator. But more importantly, as you know, you have only proved that the equality holds for a specific v.
It is clearly not true for all ##v\in V## since you took a very special ##v##, namely an eigenvector.
Fair comment, but (as an ex-mathematician turned engineer) I never use the < > notation for inner products and have to think at least twice what "adjoint operator" means :smile:
But in any case the problem here is with the math, not with the notation!
Got it. Didn't keep into consideration all v in V have to satisfy the condition . Thanks !
  • · Replies 33 ·
  • · Replies 23 ·
