How do I detect Hydrogen (efficiently and cheaply?)
  • Thread starter Thread starter marshallmeyer1
    Hydrogen
The discussion focuses on detecting hydrogen and helium in a lattice fusion reactor setup using deuterium heavy water. A mechanical approach utilizing a centrifugal pump and differential pressure measurement is highlighted, where the differential pressure correlates with the molecular weight of gases. The method effectively distinguishes lighter gases from heavier ones, although it may not differentiate between hydrogen and helium specifically. This innovative technique avoids the complications of chemical sensors, offering a reliable and straightforward solution for gas monitoring.
  • Understanding of differential pressure measurement techniques
  • Familiarity with gas properties and molecular weight calculations
  • Knowledge of mechanical analog computing systems
  • Basic principles of gas dynamics and pressure systems
  • Research the design and operation of centrifugal pumps for gas monitoring
  • Explore methods for measuring differential pressure in gas mixtures
  • Learn about mechanical analog computers and their applications in gas analysis
  • Investigate the properties of hydrogen and helium in various mixtures
This discussion is beneficial for high school students, amateur scientists, and hobbyists interested in fusion energy, gas detection methods, and mechanical engineering principles.
marshallmeyer1
Hi guys, a buddy of mine and I are high school students and we are attempting to create a lattice fusion reactor using deuterium heavy water. However, know that there are ways to detect oxygen, carbon, etc... but how would one detect hydrogen or helium?
Thanks
Lattice fusion? Are you referring to the 'Cold Fusion' experiments done back in the late 80's? If so, why are you even attempting something that has been proven false time and time again?
what concentration? In how much volume?
The pressure generated by a dead-headed centrifugal pump is in proportion to the density of the fluid being pumped. Our main generator gas monitor was a simple impeller slightly less than a foot diameter spun at 3600 rpm .
Those dimensions gave , at atmospheric pressure, differential pressure with this really handy property:
The differential when measured in inches of water was numerically equal to [itex]\frac{molecular weight}{10}[/itex].
When filled with pure hydrogen it developed 0.2 inches of water dp.
When filled with dry air it developed 1.8 inches of water.
When filled with pure CO2 it developed 4.4 inches of water.
at one atmosphere.
At higher pressures of course the dp was higher.
So the indicating part of the machine divided dp(inches of water) by absolute pressure (atmospheres) to obtain effective molecular weight.
These calculations were done by a mechanical analog computer, simple levers and linkages and a cam. The needle pointed to divisions on a scale marked:
100% H2 at one end,
100%CO2 at other,
% mix in between.
I don't think this approach would let you distinguish between Hydrogen and Helium mixed with air
but it'll sure notice when a lighter gas shows up in a heavy one.
Of course our generator ran with a hydrogen fill at 75psig(~6 atmospheres absolute) so we were watching for heavier gas showing up in a light one.
Just wanted to make you aware of a mechanical approach that I thought was clever.
It had the advantages of no fussy chemical cells to keep clean, and even if it got flooded with oil it'd pump itself dry and resume working.
Too simple to not work -- Wish i'd thought of it first!
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 66 ·
28K
  • Poll Poll
