Show that potential difference can be defined in these two ways
The discussion revolves around the equivalence of two definitions of potential difference (P.D): one expressed as P.D = {|E|} × {d} and the other as P.D = W/Q. Participants explore the relationships between electric field strength, work done, and charge, while seeking clarification on the mathematical operations involved.
  • Homework-related
  • One participant questions whether the relationship P.D = {|E|} × {d} involves a dot or cross product, indicating uncertainty about the correct mathematical operation.
  • Another participant suggests that the correct form should be E . d and emphasizes the need to prove the equivalence of the two definitions of voltage.
  • A participant clarifies that P.D refers to potential difference and W refers to work done, correcting a potential misunderstanding in the terminology used by another participant.
  • One participant provides the equation for work done as W = ∫F.dr and asserts that this is a dot product, as only the distance moved in the direction of the force is relevant.
  • Another participant draws an analogy between force and work, and electric field and electric potential, noting that this analogy can help in understanding electrodynamics problems, while also cautioning about complications introduced by magnetic fields.
Participants generally agree on the definitions of potential difference and work done, but there is uncertainty regarding the mathematical operations involved in the equations. The discussion includes multiple viewpoints on how to approach proving the equivalence of the two definitions, indicating that no consensus has been reached on the best method to derive one from the other.
Participants express uncertainty about the correct mathematical operations (dot vs. cross product) and the relationships between the various physical quantities involved, highlighting the complexity of the topic.
CraigH
Show that [itex]P.D = {|E|} × {d}[/itex] is equivalent to [itex]P.D = \frac{W}{Q}[/itex]
Potential Difference equals electric field strength meters, or work done per unit charge
(for the equation P.D = |E| X d I cannot remember if it is a dot or cross product. I'm asking this question from memory as I do not have the question sheet in front of me. Can someone please say if it is dot or cross and explain?)
[itex]\underline{F} = \frac{qQ}{\underline{r}^2} * \frac{1}{4\pi\epsilon_{0}}[/itex] * [itex]\underline{\widehat{r}}_{qQ}[/itex]
[itex]\underline{\widehat{r}}_{qQ}[/itex] Is the unit vector in the direction to get from q to Q[itex]\underline{E} = \frac{Q}{\underline{r}^2} * \frac{1}{4\pi\epsilon_{0}}[/itex] * [itex]\underline{\widehat{r}}[/itex][itex]\underline{F} = \underline{E}q[/itex][itex]V = - \oint\underline{E}.d\underline{l}[/itex]
First I made sure that the units agree with each other.
Basic units
Length = m
Mass = Kg
Time = s
Electric Current = A
So...
Force = m·kg·s-2
Work done = m2·kg·s-2
Electric field strength = m·kg·s-3·A-1
Potential Difference = m2·kg·s-3·A-1
Chrarge = s·A
E meters will have units m2·kg·s-3·A-1
Work done per unit charge will have units (m2·kg·s-2)/s·A = m2·kg·s-3·A-1
Both of these are the units of electrical potential difference so the units agree.
I then tried getting the equations to equal each other, or tried deriving one equation from the other. This is where I got stuck.
|E|=q/(4(pi)epsilon0(r^2))
|E|*r = q/(4(pi)epsilon0(r)
W = ? what equation should I use here?
Thanks for reading!
Hi CraigH! :smile:
(i think that should be E . d and W/I :wink:)
you have to prove two equivalent definitions of voltage
power/current = force "dot" distance …
how is power related to energy?
how is current related to charge?
how is energy related to work done?
how is work done related to force?
how is field related to force and charge? :wink:
I think craig was using W to mean work, in which case, it should be W/Q. Also, I think when craig is writing P.D he means potential difference, i.e. electric potential difference (voltage). (Not power times distance).
You've got the definition in your 'relevant equations' section:
[tex]V = - \oint\underline{E}.d\underline{l}[/tex]
There is a very similar equation relating force to work. If you can remember that, then you will be half-way to getting the answer.
Hi Bruce,
Yes I was using P.D for potential difference and W for work done. The equation for work done is:
W= ∫F.dr
The integral of force over distance. I believe this is also a dot product, as it is only the distance moved in the direction of the force that matters.
So I'll try to use this to equate P.D=W/Q and P.D= ∫E.dl[itex]P.D = \frac{W}{Q}[/itex]
[itex]P.D = \frac{\int F.dr}{Q}[/itex]
[itex]F=EQ[/itex]
[itex]E=\frac{F}{Q}[/itex]
[itex]P.D = \int E.dr[/itex]
Woo! I'm surprised I got this! Thank you!
Nice work man. This is such a nice analogy between (force and work) and (electric field and electric potential). Often if I get stuck on an electrodynamics problem, I think back to this analogy. But, you need to be careful, it can become more complicated if there are magnetic fields also.
  • · Replies 33 ·
  • · Replies 18 ·
  • · Replies 23 ·
