Length contraction occurs infront of AND behind you?
The discussion revolves around the concept of length contraction in the context of special relativity, specifically whether length contraction occurs for objects both in front of and behind an observer in motion. Participants explore the implications of relative motion on the perception and measurement of length contraction.
  • One participant questions whether length contraction applies to objects behind them as well as in front, suggesting a need for clarification on the phenomenon.
  • Another participant asserts that length contraction is independent of the observer's line of sight and depends solely on the relative motion between the observer and the object.
  • A different viewpoint indicates that while length contraction occurs on both sides, visual perception is affected by light travel time, which may lead to different observations than the theoretical contraction.
  • A participant expresses interest in understanding how moving towards or away from an object influences length contraction, concluding that relative velocity is the key factor, rather than the direction of movement.
Participants express differing views on the relationship between visual perception and length contraction, indicating that while some agree on the mechanics of contraction, there is no consensus on how it relates to what one observes visually.
The discussion highlights the complexity of interpreting length contraction in relation to light travel time and relative motion, with some assumptions about the observer's frame of reference remaining implicit.
coktail
If I am moving through space, things in front of me contract in the direction parallel to my movement. Does this also occur to objects behind me? For example, I look behind me, would things be contracted?
As always, thanks.
Length contraction has nothing to do with where you look or where an object is with respect to you. Any object moving with respect to you will be measured by your frame to be contracted along its direction of motion.
This is different from the visual appearance of moving objects, if that's what you are interested in.
coktail said:
If I am moving through space, things in front of me contract in the direction parallel to my movement. Does this also occur to objects behind me? For example, if I look behind me, would things be contracted?
Yes, the length contraction happens on both sides. However, that's not necessarily what you will SEE with your eyes if you turn around and look backwards because your eyes are responding to the light that hits them where you are, and that light left the object you're looking some time ago.
The thing to remember here is that length contraction and time dilation are what's left over after you've corrected for light travel time.
Thank you. I'm not too interested in the visual appearance (at least in this thread), but more about whether if I am moving towards vs away from an object makes a difference in length contraction. From your post, I gather that wether I am moving towards or away from an object is irrelevant, and what matters is the relative velocity between myself and the object?
Edit: I posted this before I saw Nugatory's reply. Thank you to both of you!
  • · Replies 63 ·
  • · Replies 78 ·
  • · Replies 54 ·
  • · Replies 45 ·
  • · Replies 17 ·
