Orbits: Elliptical vs. Parabolic
  • Context: Undergrad
  • Thread starter Thread starter Math Is Hard
    Orbits
The discussion centers around the nature of projectile motion, specifically whether the trajectory of a projectile launched at an angle is best described as a parabola or a partial ellipse. Participants explore the implications of gravitational forces and the conditions under which each model may apply, touching on historical references and practical applications in ballistics.
  • Some participants assert that the path of a projectile is a parabola, as stated in a calculus textbook, while others argue it is a partial ellipse, or "bound orbit," as suggested by an astronomy teacher.
  • One participant references historical calculations by Wiley Ley and Werner Von Braun during WWII, claiming they confirmed the elliptical nature of projectile paths for long-range artillery.
  • Another participant questions the historical accuracy of the references to Ley and Von Braun, noting that the "Paris Gun" was used in WWI, not WWII.
  • Some participants discuss the effects of air resistance and the Earth's rotation on projectile motion, suggesting these factors complicate the analysis of trajectories.
  • There is a discussion about the mathematical relationship between conic sections, with some participants noting that a parabola can be considered a special case of an ellipse with infinite distance between foci.
  • Concerns are raised about the lack of emphasis on teaching basic conic sections in educational settings, with some participants expressing disappointment over the focus on advanced topics over foundational concepts.
  • One participant suggests that the trajectory can be approximated as a parabola over short distances due to the negligible convergence of gravitational force.
Participants do not reach a consensus on whether the trajectory is best described as a parabola or a partial ellipse. Multiple competing views remain, with some supporting the parabolic model and others advocating for the elliptical interpretation.
Participants express uncertainty regarding the historical context of the references made, and there are unresolved questions about the assumptions underlying the models of projectile motion discussed.
Math Is Hard
Staff Emeritus
My Calculus textbook (Calculus , James Stewart, 5th edition, p. 720) says this: "In the 16th century Galileo showed that the path of a projectile that is shot into the air at an angle to the ground is a parabola."
My astronomy teacher says that this is not technically correct, and that the path of the projectile is actually a partial ellipse - a "bound orbit".
Which do you believe is correct? With all due respect to Mr. Stewart, (and Galileo) my money is on my Astro prof.
Thank you in advance for your response.
Astronomy news on Phys.org
The path of a projectile (bullet, rock, canon shell, etc.) is a partial ellipse. This was re-confirmed/calculated by Wiley Ley and Werner Van Braun during WWII when Germany's long "Paris guns" were missing the target. The trajectory had been calculated using a parabolic path, and the two rocket scientists had them change it to an elliptical path. They hit the target.
For short-range ballistics, like my rifles at the shooting range, or for throwing stones at streetlights, the curves of a parabola and ellipse are nearly indistinguishable (sp?). The difference shows up at larger ranges, bit it is an ellipse.
Umm, during WWII Ley was in the USA and von Braun was in Germany. And are you sure the "Paris Gun" was a WWII weapon? I am aware of a gun with that name used in WWI, but both Ley and von Braun would have been little kids then.
Agree with you about the ellipse. The parabola is what you get if the Earth is assumed to be flat (i.e. the other focus of the ellipe recedes to infinity).
And let's not forget air resistance (which is a point being strongly made in another thread (General Physics>Simple question about gravity and force), and the rotation of the Earth, and ...
All of which are, IIRC, neatly packaged into the computers which calculate the 'firing solution' for guns on warships, tanks, etc. How do they establish the range? lasers? GPS?
Ley and Von Braun co-wrote a book in the late "40's - early "50's which described the "parabola vs. ellipse" problem. I'm not sure where Ley was, but von Braun was in Germany for sure! (During WWII).
The first, and famous "Paris gun" was that 70-80 foot barreled thing in WWI that lobbed shells about 65-70 miles. But, in WWII, Germany had several huge guns on railroad cars, with crews of about 70 troops each, that were also lobbing shells at long distance. The name "Paris gun(s)" were also given to some of there early-on during the battle for France. Just as an interesting note, each shot wore a huge amount out of the barrel-bore, so each shell was numbered with each fired being larger in diameter than each previous shell. After several shots, they had to install a new barrel and start over.
This large concentration of material, manpower and other recources for so little "military gain" was the subject of a History Channel program titled "Great Blunders in History." The History Channel is where I get most of the information I post on PF...
But, I did own and read the book by Ley and von Braun a long time ago.
I was under the impression that a parabola could be thought of as a special case of an ellipse - with an infinite distance between the foci. A circle is a special case of an ellipse with zero distance between the foci.
Never heard of that. We are just talking the shapes (and math) of conic sections; circle, ellipse, parabola and hyperbola. The last two end up with diverging or parallel "edges". Only the ellipse, of the four, has two focii. (Focuses..?)...
It is true, especially at shorter ranges, that the curves of the parabola, ellipse and hyperbola are so close to each other as to be almost indistinguishable. The circle is the obvious loser.
This is really sad. They don't teach basic conic sections any more? What are the relations of the simplest ellipse equation x2/a2 + y2/b2 = 1 to the foci of the ellipse? What if one focus is moved down the x axis? How does the equation change? What is the limit of this as x -> 00?
Just curious, what's the "sad" part"?? That this is here on PF, or that they don't teach the basics anymore?
Labguy
(Ellipse-Head)
Not teaching the basics. Everyone is in such a hurry to teach calculus, advanced calculus, etc. that they don't stop to smell the "roses" of analytical geometry.
The crux of this argument lies in how you consider gravity to behave. If you expect it to act in one uniform direction (the direction of force always in parallel), then you will get a parabolic trajectory.
If you consider as acting towards a central point then you will a trajectory that is a section of an ellipse.
Of course gravity acts in the second manner so we get an ellipse.
But over small enough distances over the Earth's surface, the convergence of gravity is so small that for all intents and purposes we can treat it as acting in parallel, and we can treat the path as a parabola, depending on the degree of accuracy we need.
So I'm going to assume that it is the simplified case of parallel acting force which Mr. Stewart is talking about.
Of course, this also assumes that the velocity of the object is below escape velocity.
If it is traveling exactly at escape velocity then it actually will follow a parabolic path. At greater than escape velocity it will follow a hyperbolic path.
That is very true.
You can mathematically derive the relationship (its actually not that hard). I'm positive about the relationship between circles and ellipses, just not so sure about ellipses and parabolas.
Ah yes, that's the easiest way to look at the relationship between them. They do teach it (at least they did 15 years ago), I just forgot about it.
17K
