Does photon lose its momentum?
  • Context: Graduate
  • Thread starter Thread starter 2sin54
    Momentum Photon
The discussion revolves around the concept of photon momentum and how light can exert force, particularly in the context of solar sails. Participants explore the implications of momentum transfer when light interacts with surfaces, including the conditions under which light may lose energy or change momentum.
  • Some participants question how light can exert force if it does not change speed or wavelength after bouncing, suggesting that this implies no change in momentum.
  • Others argue that while the wavelength of light does not change in elastic reflections, the direction of momentum can change, leading to momentum transfer.
  • A participant notes that solar sails can absorb photons, which results in a change in momentum and energy, indicating a different interaction compared to simple reflections.
  • One participant emphasizes that momentum is a vector quantity, and while the magnitude of photon momentum remains constant in elastic reflections, its direction can change.
  • Another participant introduces the concept of Doppler shift, stating that the wavelength of light changes when reflecting off a moving solar sail, leading to a decrease in momentum and energy of the light wave.
  • One participant critiques the reasoning of another by clarifying that light's momentum should not be associated with speed, and that a change in wavelength alone can indicate a change in momentum, referencing Compton scattering as an example.
Participants express differing views on the relationship between light's momentum, speed, and energy transfer. There is no consensus on how these concepts interact, particularly regarding the implications for solar sails and photon behavior upon reflection.
Some discussions hinge on the definitions of momentum and the conditions of reflection, including the effects of motion on wavelength and energy. The nuances of elastic versus inelastic interactions are also highlighted but remain unresolved.
2sin54
Hello. I know that light exerts pressure. My question is how can light exert some kind of a force? If it exerts a force, it means that there has to be a change in momentum but light clearly can't go slower and it doesn't change its wave length after the bounce. If it is able to move a solar sail, it means the light has to lose some energy to do the necessary work. What am I missing here?
If light bounces off an object, it reverses its direction and therefore its direction of momentum. This leads to a momentum transfer on the mirror.
It does change its wavelength in systems where the mirror is moving.
Solar sails can absorb a part of the photons, which gives momentum (and energy) as well.
Momentum is a vector, not a scalar. Momentum has a direction in addition to a magnitude.
The magnitude of momentum is Planck's constant divided by wavelength. If the wavelength doesn't change, then the magnitude of momentum doesn't change. However, the direction of momentum can change. In an elastic reflection, the magnitude of photon momentum does not change. However, the direction of the photons changes.
In this particular way, quantum mechanics is the same as Newtonian mechanics. A photon bouncing off a mirror is no different in terms of momentum than a rubber ball bouncing off a brick wall. The magnitude of momentum doesn't change, but the direction of momentum changes.
The case of the solar sail is different because the solar sail can move. The wavelength of the light does change after bouncing off the solar sail due to Doppler shift. In the inertial frame of the sun, the light bouncing off the moving sail decreases in frequency due to Doppler shift and increases in wavelength.
The reflection off of the solar sail is not elastic in the inertial frame of the sun. Because the wavelength of light increases, the magnitude of momentum of the light decreases. Because the frequency decreases, the energy of the light wave decreases.
The photon bouncing off of the solar sail is like a pool ball bouncing off of another pool ball. The magnitude of the first pool ball decreases because the second pool ball starts moving.
Better: a ping-pong ball bouncing off a bowling ball.
The fatal flaw in your reasoning here is to associate light's momentum with "speed". Nowhere in the definition of momentum for light was this ever defined that way. One may write light's momentum as
p = h/lambda
where lambda is the wavelength. So simply showing a change in wavelength of light (without changing its speed) is sufficient to show a change in momentum. An example of this is in Compton scattering.
Zz.
Thank you all.
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 81 ·
