Are Statistical Mechanics Adequate for Interstellar and Intergalactic Clouds?
The discussion revolves around the adequacy of statistical mechanics in describing the behavior of interstellar and intergalactic clouds of gas and dust. Participants explore the implications of low particle densities in these environments and the nature of interactions, such as collisions and shock waves.
  • One participant expresses concern that the low densities in interstellar and intergalactic clouds may undermine the premise of statistical mechanics, as most particles may not experience collisions.
  • Another participant explains that the probability of collisions is extremely low, using a hypothetical scenario to illustrate the vast distances between stars and particles in nebulae.
  • A different participant questions how intersecting clouds can produce shock waves despite the sparse nature of the medium, noting that solar particles and nova ejecta do create shock waves.
  • Another participant mentions that interstellar shock waves can originate from various sources, including supernovae and solar winds, and references an article for further reading on the topic.
Participants generally agree that the probability of collisions in interstellar and intergalactic clouds is low, but there is uncertainty regarding how this affects the application of statistical mechanics and the nature of shock waves in these environments. The discussion remains unresolved regarding the implications of these factors.
Participants highlight limitations in visualizing interactions within sparse clouds and the complexity of shock wave generation, which may depend on various conditions and sources.
anorlunda
Staff Emeritus
Insights Author
I understand statistical mechanics. I understand that PV=nRT has no lower bound on density. Yet I'm bugged by the thought that the densities in interstellar (or even intergalactic) nebulas are so low that most particles will never experience any collisions at all, thus undermining the premise of statistical mechanics.
I understand that some of the particles are charged, but dust clumps of molecules are neutral.
I looked up the speed of sound in space (300 km/s), I see pictures on APOD clearly showing shock waves in planetary nebula or supernova remnants, or at the boundaries of the solar system where Voyager is heading. Some shock waves seem driven by radiation pressure, others not.
On the other hand galaxies pass through each other all the time with seemingly no effect other than gravity. The other day on APOD they even showed the galaxy Messier 64 and said that it is two concentric counter rotating galaxies coexisting. How the heck can that happen without lots of violent collisions between nebula?
The visible evidence seems contradictory. It bugs me; my left brain says the particles collide frequently, my right brain says most particles never collide with anything.
Here's my question. Are ordinary statistical mechanics sufficient to describe interstellar and intergalactic clouds of gas and dust, or is there something big I'm missing?
Astronomy news on Phys.org
Your right that the probability of collisions or nebulae is extremely low but it sounds like you are having trouble understanding why.
Let's take a hypothetical collision for simplicity we will ignore dust. Set the average distance between stars at 1 light year apart for both galaxies. (this is far denser than average).
Knowing this calculate how much space is between two stars. Once you perform this calculation you will quickly realize the diameter of a star would be like a grain of sand on a football field. Two football regions cross each other what would you think the likely hood of two grains of sand colliding?
then consider that nebulae form stars with those separation distances. Let's just say even
particles in a nebulae have a lot
of room between particles.
Here is a good experiment to see how dust interacts. Take a handful of talcum powder and have a friend do the same. Stand one meter apart. Throw the two handfuls towards each other. You may have to stand closer.
How many particles do you see
collide? Their might be a few but it would be so miniscule it would be unmeasurable.
Thank you Modred. But is I start with the very sparse mental model I have a hard time visualizing how intersecting clouds could cause shock waves in each other.
Clearly, the stream of solar particles causes shock waves at the edge of the solar system, and nova ejecta cause shock waves.
The talcum powder analogy illustrates the non-interaction of sparse clouds, but in my mind shock waves illustrate the strongest imaginable kind of interaction.
Interstellar shockwaves have a few different sources or reasons. Some from supernovae, or explosions, some from interactions with the solar winds there are othre causes as well.
here is one article bom Berkely that discusses some of the principles and mathematics.
http://astro.berkeley.edu/~ay216/05/NOTES/Lecture11.pdf
if you look up interstellar shockwaves you can find numerous related articles
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 17 ·
