Power Needed to Accelerate 700kg Car from Rest
  • Thread starter Thread starter johnnyb
The discussion revolves around calculating the power needed for a 700kg car to accelerate from rest under constant power, given its position and acceleration at a specific time.
  • Participants explore the relationship between power, work, and force, with some attempting to derive power using basic physics equations. Others express confusion regarding hints suggesting integration and the complexity of the problem.
There is an ongoing exploration of different approaches to the problem, with some participants providing mathematical relationships and others questioning the simplicity of the initial methods. Guidance has been offered through mathematical derivations, but no consensus has been reached on a definitive solution.
Participants are navigating hints that suggest a more complex relationship involving integration, which has led to some uncertainty about the problem's requirements and assumptions.
johnnyb
Hey guys any help on this question would be much appreciated
A 700kg car accelerates from rest under constant power at t = 0. At t = 9s it is 117.7m from its starting position and its acceleration is then 1.09m/s2. Find the power, expended by the car's engine, neglecting frictional losses.
Power = Work / Time
Work = Force x Distance
Force = Mass x Acceleration
Power = Mass x Acceleration x Distance / Time
I thought of that, but below that it says
Hint: Start with the relationship between Power and Force, rearrange differentials to intergrate
This just confused me, and I thought maybe it wasn't that simple as what you posted above
All the integration will lead to the answer I gave you above.
But in that case:
[tex]dW = P dt[/tex]
[tex]dW = F dx[/tex]
[tex]P dt = F dx[/tex]
Integrating both sides:
[tex]\int { P dt } = \int { F dx }[/tex]
[tex]Pt = Fx[/tex]
[tex]P = \frac{Fx}{t}[/tex]
Thats as differential as I can get.
Ok thanks very much for your help
  • · Replies 20 ·
  • · Replies 48 ·
10K
  • · Replies 17 ·
