Hypothetical thought experiment about time dilation
The discussion revolves around a hypothetical thought experiment concerning time dilation as described by the theory of relativity. Participants explore the implications of traveling at relativistic speeds, particularly approaching the speed of light, and the resulting effects on time experienced by the traveler versus observers on Earth.
  • One participant proposes a scenario where traveling at increasing fractions of the speed of light results in significantly greater time passing on Earth compared to the traveler's experience.
  • Another participant asserts that it is impossible to reach the speed of light, emphasizing that the energy required increases without bound as one approaches light speed.
  • Some participants discuss the implications of hypothetically reaching the speed of light, questioning whether this would mean bypassing time entirely and suggesting that infinite time would pass on Earth.
  • There is a mention of the mathematical relationship between speed and time dilation, with one participant suggesting a pattern in the time dilation factor as speeds approach light speed.
  • Another participant points out that even in a thought experiment, the premise of reaching light speed contradicts the principles of relativity.
  • One participant acknowledges a flaw in their initial hypothetical scenario after receiving feedback, indicating a recognition of the limitations of their thought experiment.
Participants express disagreement on the feasibility of reaching the speed of light and the implications of such a scenario. While some explore the hypothetical consequences, others emphasize the constraints imposed by relativity, leading to an unresolved discussion regarding the nature of time at light speed.
Participants acknowledge that the thought experiment relies on assumptions that contradict established physical laws, particularly the impossibility of massive objects reaching the speed of light. The discussion also highlights the limitations of hypothetical scenarios in accurately reflecting physical reality.
awalltep81
Let's say that you leave Earth at 75% the speed of light (c). You travel out and back for a minute. And when you come back an hour has passed on Earth. (I understand this is not accurate; I'm just using it for the sake of this hypothetical) You leave again at 99% of c, again for a minute. When you get back to Earth, a day has passed. You do it again at 99.99999% of c. You come back to Earth and 10 years has passed. Again at 99.99999999999% and 10,000 years has passed. You can keep adding 9 onto the end of that percentage, and the one minute you travel will be more and more time for those left behind.
Isn't it true, then, if you are actually able to hit the speed of light, that means upon "returning" you've completely bypassed time itself? Shouldn't an infinite amount of time have passed? Since you can "bypass" (can't think of a better word) any measurable amount of time by getting closer and closer to c, wouldn't it make sense that to actually hit c would be to "bypass" an immeasurable amount of time?
It turns out you will not be able to accelerate to the speed of light relative to the Earth. The more energy you expend from your engine, the faster you will get, up toward - but not including - the speed of light.
I know you can not actually reach the speed of light. It's kind of a "what if"?
Yes, relativity says it is impossible for any "massive" object to move at the speed of light. So even in a "thought experiment" you cannot say "if you are actually able to hit the speed of light". You are essentially asking "if relativity were wrong, what would relativity say about this situation?"
The faster you go, the slower your clock ticks relative to Earth. For "an infinite amount of time" to pass, you would have to travel while ∞ time passed on Earth. Presumably the Earth will not last that long. There might be a big crunch.
[edited to turn it around]
The larger and larger you make x, the smaller and smaller 1/x becomes. Doesn't it make sense that for x to "actually hit" infinity, then 1/x would be zero? Anyhow, no mass can ever be accelerated to the speed to light.
Ok. I never realize that flaw in the hypo. Thanks.
Just for the fun of it, I'm going to modify your question to bring it in line with reality. I realize you were not concerned with the details so I'm not faulting you on this point.
If we start with a speed of 99% of c, the time that will pass on Earth will be 7.088812 minutes. If, instead of adding a single 9 onto the end of the percentage, we add a pair of nines, the time will go up by about a factor of 10. So at 99.99%c, 70.712446 minutes will transpire on Earth. At 99.9999%c, it is 707.106958 minutes on Earth. We can see a pattern here and if we realize that the factor approaches the square root of one-half (0.70710678118654752440084436210485) times a power of ten, then we can easily predict what the factor is for speeds as close to the speed of light that we desire. But no matter how many pairs of nines we want to add onto the end of the percentage, the digits in the factor will always approach that of the square root of one-half. So, for example, with 30 pairs of nines in the percentage of the speed of light, the factor will be 707106781186547524400844362104.85 minutes. Now that is a very long time, much longer than the age of the universe but still no where near infinity.
  • · Replies 46 ·
  • · Replies 55 ·
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 65 ·
14K
  • · Replies 58 ·
  • · Replies 18 ·
