Maxwell's Eq, Magnetic Monopoles, GR & Gravimag. Monopole?
  • Context: Graduate
  • Thread starter Thread starter Spinnor
    Gr Linear Monopole
The discussion explores the potential for incorporating magnetic charge into Maxwell's equations and its implications for General Relativity (GR). Participants consider whether modifications to these equations could introduce an equivalent of magnetic charge in GR, examining both theoretical frameworks and specific solutions.
  • Some participants propose that if magnetic charge exists, Maxwell's equations could be modified to include it, specifically suggesting that the equation ##\nabla\cdot\mathbf{B}=0## would need to be altered.
  • Others argue that changes to Maxwell's equations would necessitate corresponding changes to the Einstein-Maxwell equations, although the specifics of these changes are not detailed.
  • A participant mentions that introducing magnetic monopoles into Maxwell's equations might require a topological defect, such as a Dirac string.
  • There is a suggestion that General Relativity can be expressed in a form analogous to Maxwell's equations under certain conditions, particularly at small field strengths and velocities.
  • One participant identifies Taub-NUT space as a solution in GR that generalizes Schwarzschild and includes a "NUT parameter," which could be interpreted as a gravitomagnetic charge.
Participants express varying views on the implications of magnetic charge for both Maxwell's equations and General Relativity. There is no consensus on how these modifications would be implemented or their consequences.
Participants reference specific theoretical constructs and solutions, such as gravitomagnetism and Taub-NUT space, but the discussion remains open-ended regarding the broader implications and the exact nature of the proposed modifications.
This discussion may be of interest to those studying theoretical physics, particularly in the areas of electromagnetism and general relativity, as well as researchers exploring the concept of magnetic monopoles.
Spinnor
If there was magnetic charge Maxwell's equations could be altered to accommodate the magnetic charge?
For small field strength and velocities General Relativity can be put in a form similar to Maxwell's equations?
If so is there something that could be introduced into General Relativity (or is already there?) that would be the equivalent of magnetic charge?
Thanks for any help!
##\nabla\cdot\mathbf{B}=0## would have to go.
If Maxwells equations change then the Einstein-Maxwell equations will change. I can't tell you how off the top of my head.
AFAIK only by introducing a topological defect(Dirac string) can magnetic monopoles be introduced in Maxwell's eq.
There is an approach to GR that highlights the analogies with EM, look up gravitomagnetism and frame-dragging: http://en.wikipedia.org/wiki/Gravitoelectromagnetism
Yes, Taub-NUT space is a spherically symmetric vacuum solution that generalizes Schwarzschild. It contains an additional "NUT parameter" which plays the role of a gravitomagnetic charge.
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 37 ·
