Register to reply
Shear calculation for round pipe
by Bernard Dubois
Tags: calculation, pipe, shear
Share this thread:
Bernard Dubois
#1
Apr8-13, 10:31 PM
P: 1
Can someone please help me.
I have a pipe 200mmOD x 160mmID welded to a Steel structure
The pipe is 100mm long with a 12mm plate x 250Dia welded at the end of the pipe.
The steel structure weighs 7500Kg
I have to lift the structure with a crane. The crane has a cable with a loop which can fit around the pipe.
question:
Will the pipe be strong enough given the standard safety lifting requirement is 2.5:1
Thanks
Phys.Org News Partner Engineering news on Phys.org
UConn makes 3-D copies of antique instrument parts
Amazon worker piloted drone around Space Needle
Five next-generation technologies for positioning, navigation and timing
SteamKing
#2
Apr9-13, 12:58 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,301
It's not clear from your description how this lift is to be accomplished. Is there one pipe or more than one pipe? What is the size of the structure being lifted? Where are the pipe or pipes located on the structure with respect to the c.g. of the structure?
IMO, you should engage an engineer to review your lift plans.
Register to reply
Related Discussions
I-beam Shear Force calculation Materials & Chemical Engineering 3
Shear Calculation Estimate Materials & Chemical Engineering 0
Shear flow axial deflection a pipe General Engineering 0
Static pressure in round pipe bends do what? General Physics 0
Shear Strength of an Erected Pipe General Engineering 4
