Solution to Fourier Transform of f(θ) = |sin(θ)|
The discussion revolves around finding the Fourier transform of the function f(θ) = |sin(θ)|, with participants exploring various methods and approaches to tackle the problem.
  • Participants discuss the potential need for complex analysis versus integration by parts, with some expressing frustration over the latter's complexity. Questions arise regarding the applicability of standard integration techniques and the role of trigonometric identities in simplifying the problem.
There is an ongoing exploration of different methods, including the use of trigonometric identities and integration techniques. Some participants suggest alternative approaches, but no consensus has been reached on a specific method to solve the problem.
Participants note the challenge of integrating functions with different parameters and the potential limitations of their current knowledge regarding Fourier transforms and trigonometric identities.
Stu165
I need to show the solution to the Fourier transfor of f(theta) = |sin(theta)|.
However i think that solving this needs to be done by complex anaylsis as integration by parts just keeps going on and on.
Does anyone know where to go with this?
Does it provide an equation you can solve? Integrating [itex]\int e^x \sin x \, dx[/itex] is a standard IBP problem -- I bet it's in your calc 2 text. :smile:
I need to find
1/pi int sin(theta)cos(mk theta) d theta from 0 - pi
pi being the period
excuse the type I don't know how to do the equation thing.
I only find the cosine part of the transform cause it's and even function, therefore I don't integrate any sine components at the start. If that makes sense.
Sorry, I'm used to the exponential version. :smile:
All of your problems are solved with a simple trigonometric identity -- you can change a product of sine and cosine into a sum of two sines. I don't remember the exact form, but you can derive it yourself. Hint: consider sin(A+B) + sin(A-B).
(But, as you guessed, you could also do this by replacing cos x with Re[e^(ix)])
[tex]sin(2x) = 2 sinx cosx[/tex] but in this case sin and cosin have different parameters. I don't know how you'll go about that.
:-p
forgot to look at trig identities yet. I'll try that
