Size of VY Canismajoris and gravity
  • Context: Undergrad
  • Thread starter Thread starter SecretOfnumber
    Gravity
The discussion revolves around the differences in size between stars, specifically comparing VY Canis Majoris and OGLE-TR-122b. Participants explore the factors that contribute to the varying sizes of stars, including gravity, gas composition, and the processes involved in star formation. The conversation touches on theoretical and observational aspects of stellar sizes.
  • One participant questions the reasons behind the significant size difference between the smallest and largest known stars, suggesting gravity's role in determining size.
  • Another participant explains that stable stars maintain an equilibrium between outward pressure and inward gravity, with heavier stars generating more radiation pressure.
  • A participant emphasizes that VY Canis Majoris is one of the largest stars known but cautions that there may be larger stars yet to be discovered, noting the challenges in measuring distant stars.
  • There is a discussion about the volume of gas required to form stars of different sizes, with calculations presented to compare the gas cloud volumes needed for VY Canis Majoris and OGLE-TR-122b.
  • One participant expresses curiosity about the factors that lead to different star sizes and the role of gravity in this process, questioning the homogeneity of gas in the early universe.
  • Another participant discusses the instability of perfect homogeneity in gas clouds and how localized density spikes can lead to star formation, influenced by various factors such as angular momentum and temperature.
  • A later reply elaborates on the randomness of material accumulation in star formation and the mass-radius relationship, noting that more massive stars tend to be larger due to higher core compression and radiation pressure.
  • One participant mentions that the elemental composition of the molecular cloud can influence star size, with heavier elements leading to denser stars that initiate fusion earlier.
Participants express a range of views on the factors influencing star size, with no consensus reached on the specific mechanisms or the implications of gravity in this context. The discussion remains open-ended with multiple competing perspectives.
Some participants highlight the limitations of current measurements and the challenges in defining homogeneity on different scales, suggesting that the discussion is influenced by the complexities of stellar formation and the nature of gas clouds.
SecretOfnumber
Smallest known star is OGLE-TR-122b and the biggest star in the universe is Canismajoris VY , now my question is :
what cause these two to be so different in shape? if the gravity is the planer for size, then how VY could become so huge in size before start collapsing?what volume of gas setup to create such a monster?!
Thanks
Astronomy news on Phys.org
Stable stars are in an equilibrium of pressure (outwards) and gravity (inwards). Pressure is mainly radiation pressure and comes from the release of energy in the core (due to fusion). Heavier stars release more energy, so they tend to have a higher radiation pressure, pushing away the outer parts. The age and the composition of the star is relevant, too.
Thanks
Let's not get ahead of ourselves. It's one of the largest stars by volume known in our galaxy.
This is not to say there are no larger ones, even within Milky Way. E.g., https://en.wikipedia.org/wiki/NML_Cygni. These stars are barely ~4-6kly away, at the edge of our ability to measure properties of individual stars. Compare to the diameter of the Galaxy: 100kly.
And let's not even mention the whole universe.
As for the VY CMa, it's only ~18 times as massive as the Sun and 180 times as massive as OGLE-TR-122b.
Therefore, you need 180 times as much of relatively cold gas(by mass) to make the larger one than you need for the smaller one.
Let's compare the volumes of gas clouds:
[tex]ρ\frac{4}{3}πR_1^3=m_1[/tex]
[tex]ρ\frac{4}{3}πR_2^3=m_2[/tex]
ρ is the density of the gas cloud
substituting
m1=180m2
[tex]R_1^3=180R_2^3[/tex]
[tex]R_1=180^\frac{1}{3}R_2[/tex]
[tex]R_1~=5.6R_2[/tex]
So you need just over five times larger(in radius) a gas cloud to produce CV CMa than OGLE-TR-122b.
Thanks Bandersnatch,
You R right 1 of the Biggest "Known" star!
The other thing I would love to know is What causes the different size of stars? how "gravity" decide to make different sizes ?(I suppose gravity should become to the action after she made the star "GR gravity" wasn't the gas homogenous after cooling down of the universe?
Cheers
The size of stars is determined by the availability of gases
As far as gases being homogeneous in the early universe one needs to consider that matter such as gases will quickly start to condense. So that even distribution will quickly change.
I should also point out that the term homogeneous is a term that in many descriptives or models is a term that can only be described at different size scales.
for example we describe our current universe as homogeneous, on a scale below 100Mpc we have galaxies,stars, large empty spaces etc.
So in this case we can only apply the homogeneous term on scales larger than 100 Mpc
Let me elaborate on Mordred's comment.Perfect homogenity is unstable, in the same way as a needle standing on its sharp end is. It tends to be disrupted by the slightest of random motions and never reverts to the initial state.
Once a localised density spike appears in a uniform gas cloud, it gets exaggerated as it collapeses, and forms structures like groups of galaxies, galaxies themselves, stars and planets, depending on scale. Further collapse can be stopped by the conservation of angular momentum and (on small scales) internal kinetic energy of gas molecules(temperature) and radiation pressure.
Here's a nice simple program on Khan Academy that simulates a small, rotating cloud of particles collapsing under its own gravity:
http://www.khanacademy.org/cs/challenge-modeling-accretion-disks/1180451277
It might help in visualising the "lumping" of material.
You can change the variables, including the rotation and "star" formation rules.
Anyway. Gravity works well if the time scale is huge, or spatial scale is small(stars, planets etc.). So, once you end up with lumps of gas floating around a galaxy, they tend to stay roughly undisturbed. They're very diffuse, and often hot, so significant gravitational collapse might not happen for a very long time.
Usually there's some event that triggers the collapse, like an earlier star exploding and sending shockwaves through the medium to compress it enough. How much material ends up in any given star ends up pretty much random. (the program linked above illustrates this unpredictability)
So now you've got a number of stars with a range of masses. In the early stages of their lives(http://en.wikipedia.org/wiki/Main_sequence), it is only mass that determines their size. The larger the bigger(and brighter and hotter).
More massive stars' cores are compressed more highly than low-mass ones, so they produce more heat that pushes the outer parts outward. So the mass-radius relation is different from what you might expect from e.g., the constant density calculations in my post #3.
It looks something like this:
http://www.daviddarling.info/encyclopedia/M/mass-radius_relation.html
(it changes a bit depending on mass range)
The most massive stars theoretically possible have(iirc) ~250 solar masses(more massive would produce enough energy to blow away the extra mass). This one is close:
http://en.wikipedia.org/wiki/R136a1
And it's only ~35 times the radius of the sun.The really huge stars are all in their last phases of life, swelling to enormous proportions due the changing composition of their cores.
http://en.wikipedia.org/wiki/Stellar_evolution
Edit: the one factor I can think of that might influence the size of a star is the elemental composition of the collapsing molecular cloud.
Clouds with heavier elements will produce denser stars that will start fusion earlier. The resultant radiation flux will blow away the surrounding material that otherwise would accrete onto the star.
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 51 ·
10K
  • · Replies 42 ·
