eNathan
- 351
- 2
I know this question was covered here in the past, but I got some mixed answers. I hope somebody can clear this up for me.
The discussion centers on the relationship between relativistic mass and gravity, exploring whether relativistic mass contributes to gravitational effects. Participants examine theoretical implications, equations, and experimental evidence related to general relativity and gravitational interactions, including kinetic energy and momentum.
Participants express differing views on the contribution of relativistic mass and kinetic energy to gravity, with no consensus reached on the nature of these contributions or the implications for gravitational interactions.
Participants highlight the complexity of gravitational interactions at relativistic speeds, noting that traditional views may not apply and that the curvature of space-time becomes significant. There are also mentions of unresolved mathematical steps and the dependence on definitions in the discussion.
eNathan said:Well, thank you for a clear answer :) Someone told me before that it does not contribute to gravity at all. Is there an equation to express its Gravitational effects? (But of course there is, what is it?)
According to the general theory of relativity, kinetic energy contributes
to gravitational mass. Surprisingly, the observational evidence for this
prediction does not seem to be discussed in the literature. I reanalyze
existing experimental data to test the equivalence principle for the
kinetic energy of atomic electrons, and show that fairly strong limits
on possible violations can be obtained.
pervect said:http://lanl.arxiv.org/PS_cache/gr-qc/pdf/9909/9909014.pdf
is still the best reference I've found online.
A similar case has been discussed in the "https://www.physicsforums.com/showthread.php?t=225573" showed that what you described may be a coordinate independent effect. AFAIK, the issue was not quite resolved in that thread.cos said:In the thread 'Mass dilation' I referred to Colin Ronan's comment in Deep Space that when a particle is accelerated in a cathode ray tube it will curve downwards and must be bought back to its horizontal path using a magnetic field applied beneath the particle.
Ronan's additional comment, that if the particle is accelerated to a greater instantaneous velocity it will curve further down as a result of the planet applying a stronger gravitational force thereby requiring the application of an increased force beneath the particle, has been ridiculed presumably on the basis of the particle's increased inertia i.e. the planet's gravity creates a vertical displacement of 9.8m/sec/sec irrespective of the particle's mass as determined by Galileo.
On the basis that an increase in the particle's velocity-mass exponentially increases the particle's inherent gravitational field strength it seems that Ronan's comment is correct.
starthaus said:It hasn't been "ridiculed"...
starthaus said:Ronan is confused, the effect is due to the Lorenz force qvxB.
starthaus said:The Lorentz force curves the particle path...
Jorrie said:It seems that things fall at the same acceleration in any single frame, irrespective of 'horizontal' velocity.
cos said:Ronan's comment has been ridiculed in other groups!
Perhaps Ronan was addressing his comment to ignorant types such as myself (in his physics popularization publication) in a fashion that we might more easily understand rather than him talking about the Lorenz force and providing that equation.
You say 'the effect is due to the Lorenz force'. What effect?
Are you talking about Ronan's suggestion that the faster accelerated particle will fall further down on the target screen (i.e. 'an effect')?
It is not the theoretical Lorenz force that curves the particle's path! The particle's path is curved by gravity!
cos said:A point is that the two particle's, having been accelerated to different instantaneous velocities (particle B has been accelerated to a higher speed than particle A), will not have been accelerated at the same rate ergo are not in the same, single, frame either whilst accelerating (at different rates) or when they strike the target at different speeds.
cos said:Imagine two identical particle accelerators alongside each other; one of them applies a certain amount of force to make its particle (A) accelerate whereupon that particle strikes the target screen at a point below the horizontal.
Jorrie said:Yes, but we can choose to measure both particle's accelerations in one single inertial frame. In that frame they both fall at the same acceleration, while in the surface (or accelerator) non-inertial frame, they do not.
Jorrie said:A similar case has been discussed in the "https://www.physicsforums.com/showthread.php?t=225573" showed that what you described may be a coordinate independent effect. AFAIK, the issue was not quite resolved in that thread.
Jorrie said:As I now understand it, the effect is coordinate dependent and can be 'gauged away', as Carlip wrote in http://arxiv.org/PS_cache/gr-qc/pdf/9909/9909014v1.pdf" (pdf referenced above). It seems that things fall at the same acceleration in any single fame, irrespective of 'horizontal' velocity.
But, I'm not sure that I understand this correctly...
Jorrie said:If so, then in a way it is motivation for "horizontally fast moving things fall faster in a gravitational field". (?)
kev said:For example, if two particles are initially at the same location and one (A) has zero horizontal velocity and the other (B) has a horizontal velocity of 0.8c, then both will hit the ground simultaneously (from the point of view of the observer at rest with the ground and ignoring orbital effects).
kev said:If I understand (your interpretation of) Carlip's claim correctly, he is in effect claiming that if two spatially separated events are simultaneous in one frame, then they are simultaneous in all inertial frames, which flies in the face of all we know about relativity and using fancy terms like "gauged away" does not hide that flaw in his argument.
Jorrie said:Anyway, to me this is still a somewhat confusing issue and would very much like to hear Pervect's take on it.
kev said:[tex] F = \frac{GM}{r^2} + \frac{3GMv^2}{r^2c^2} - \frac{v^2}{r}[/tex]
The middle term on the right is an additional term unique to GR that can be thought of in terms of the effect of curvature of space (maybe).
