Master Free Body Diagrams: How to Draw Them for Different Scenarios
The discussion revolves around the concept of Free Body Diagrams (FBDs) in physics, particularly in scenarios involving objects in motion, such as those at terminal velocity, at the peak of a parabolic trajectory, and on an inclined plane. Participants are exploring how to accurately represent the forces acting on these objects in their diagrams.
  • Participants discuss the forces acting on an object at terminal velocity, questioning if gravitational force and air resistance are equal. They also explore the forces at the peak of a parabolic trajectory, debating whether air resistance should be included. Additionally, there are inquiries about the role of friction in FBDs for objects on ramps.
There is an ongoing exploration of the correct representation of forces in FBDs, with some participants providing insights into the nature of forces acting on objects in different scenarios. Multiple interpretations are being considered, particularly regarding the inclusion of air resistance and the effects of applied forces.
Participants are navigating assumptions about neglecting air resistance in certain contexts and the implications of forces acting on objects in motion, particularly in freefall and during projectile motion.
jen333
Free Body Diagrams...help please!
hello hello,
i'm just having a bit of difficulty concerning free body diagrams:
how would i draw an FBD for the following...
a) an object has reached terminal velocity. would this mean that the object has reached a constant velocity, therefore force gravity and air resistance are the same?
b)an object is at the top of a parabolic trajectory. once again, does that mean that the object is simply at a constant velocity and should be drawn with both Fg and Fair resistance as being even. OR...is the object still following and therefore only draw Fg (force gravity)?
c)a ball on a ramp is block from slidding down the ramp. i have the Fn and Fg of the FBD, but I'm just wondering if friction would come in hand in this diagram due to the block.
Assistance greatly needed! :D
thank you!
a) yes, the object would have two opposing vectors, one for gravity and one for air resistance. the resulting vector is a constant velocity vector downwards.
b) when you throw a tennis ball straight up in the air, wha happens at the top of the trajectory? think about what defines the top of the trajectory
c) I think you mean its being blocked, like somethings holding it. In which case you have your gravity vector, and two normal forces holding the ball up. there's two because the normal force from the ramp isn't equal to the force of gravity, the block provides another normal force to completely neutralize the force of gravity.
trajectory...?
i'm really not understanding this. (throwing a ball in the air). i know that as gravity overtakes the object while its in the air, it slows down, and then accelerates falling back down...
or
does this mean that gravity is overtaking the object.
^ F air resistance
l
l
o
l
l
l
l
\/ Fg ?!
Usually you neglect air resistance unless told to include it, but that force diagram is correct once the ball starts falling. At the peak of the trajectory, there is no motion, so no air resistance.
confirmation
so you're saying that the FBD of this should only contain Fg, therefore:
O
l
l
l
\/ Fg
so then, if an object was to rise in a parabolic trajectory, it would also only have Fg and no applied force or air resistance?
ps) thanks for your help! :smile:
In simple freefall, anything takes a parabolic trajectory. The only force acting in freefall is gravity. Gravity is also the only force acting when something is thrown upwards.
The tennis ball example: When you throw a ball upwards, as soon as the ball leaves your hands, the only force acting on it is gravity, until it hits the ground.
Air resistance is a much more copmlicated function which depends on the speed of the object, and is usually neglected for the purpose of teaching basic kinematics
alright, i think i know where you're getting at. there's only one thing that's stumping me. if gravity is the only force acting upon an object which leaves your hands once thrown into the air, another force has to overcome the force of gravity to go up. so wouldn't that be applied force placed on the object in order to project it?
A force creates a momentum in the direction. When you apply the force, you build up momentum on your hands, once you let go that momentum is no longer increasing. As soon as you let go of the ball, at no point is it speeding up. Force causes a change in momentum. The force of gravity is decreasing the momentum of the ball (momentum is mass times velocity).
AH! I see...
so if I'm getting this, and please tell me i am, no matter where an object is once it's projected (rising or falling) it was be at a constant velocity and the only force acting upon it is gravity.
thus, the free body diagram of this situation would simply be:
O
l
l
l
\/ Fg
...throughout the entire time it is in the air...?
Your free body diagram is correct, The object isn't at constant velocity though, because it is being accelerated by gravity. The net force on the object is gravity. If there is no net force, or the net force = 0, then the velocity is constant.
Im sorry I can't explain this better to you.
jen333 said:
AH! I see...
O
l
l
l
\/ Fg
Yes, in free fall the only force is downward pointing force of Gravity. Whether it drops, is thrown upwards, follows a 2D parabola...
Regarding your question about an object sliding down a ramp, there are usually three forces: downward pointing Gravitational force, force of Friction that is opposite to the direction of motion, and the Normal force that is perpendicular to the ramp surface.
  • · Replies 25 ·
