When is classical mechanics valid for describing motion of atoms?
Classical mechanics is valid for describing atomic motion in Molecular Dynamics simulations when the thermal de Broglie wavelength, defined as $$\Lambda=\frac{h}{\sqrt{2\pi mkT}}$$, is significantly smaller than the interparticle distance. This criterion allows for the use of Newton's equations of motion, which provide a direct trajectory description, as opposed to the probabilistic nature of the Schrödinger equation. The adequacy of classical mechanics is supported by principles such as the kinetic theory of gases and Ehrenfest's theorem, which connects quantum mechanics to classical behavior.
  • Understanding of Molecular Dynamics simulations
  • Familiarity with the Schrödinger equation
  • Knowledge of Ehrenfest's theorem
  • Basic concepts of kinetic theory of gases
  • Study the derivation of Newton's equations of motion from the Schrödinger equation
  • Explore the implications of the thermal de Broglie wavelength in various physical systems
  • Investigate the applications of Ehrenfest's theorem in quantum mechanics
  • Learn about the kinetic theory of gases and its relation to classical mechanics
Researchers in physics, particularly those focused on molecular dynamics, quantum mechanics, and classical mechanics, as well as students seeking to understand the transition between quantum and classical descriptions of motion.
Arham
Hello. In Molecular Dynamics simulations, the Newton's equation of motion is used to calculate the time evolution of system. Once, I read in an introductory text that when the thermal de Broglie wavelength $$\Lambda=\frac{h}{\sqrt{2\pi mkT}}$$ is much smaller than the interparticle distance, using classical mechanics is justified and it can be used instead of quantum mechanics. Why? I mean I'd like to start from the Schrödinger equation or a theorem which is based on it (e.g. Ehrenfest's theorem) and using the above criterion obtain the Newton's equation of motion.
May you help me?
It is not easy to derive the Newton equations of motion from Schroedinger's equation alone, because the latter is usually though to be only a probabilistic description of the motion of the particles, while the Newton equations are direct description of trajectory. It is like with diffusion equation - you can't use it to derive trajectory of a Brownian particle.
The reason why the Newton equations are used is rather that they are simple and there are good reasons to think they are adequate - kinetic theory of gases...
  • · Replies 376 ·
26K
  • · Replies 212 ·
29K
  • · Replies 135 ·
13K
  • · Replies 44 ·
