Scanning values to structs in C
  • Thread starter Thread starter mathmannn
    Scanning
The discussion revolves around the use of structs in C programming, specifically focusing on how to properly pass an array of structs to a function for inputting values. Participants are exploring issues related to function calls, array indexing, and variable access within structs.
  • Homework-related
  • One participant shares their code for storing the dimensions of rectangles using structs and expresses confusion about moving input functionality into a separate function.
  • Another participant points out that there is a difference between accessing the struct members using "length" and "len," suggesting that this could be a source of error.
  • A participant highlights that the original function call attempts to access an array index that is out of bounds, recommending a corrected function call.
  • There is a request for clarification on the concept of accessing beyond the end of an array, indicating a lack of understanding about how array indexing works in relation to user-defined input.
Participants do not reach a consensus on the best approach to resolve the issues presented, as there are multiple suggestions and corrections offered without definitive agreement on a single solution.
Limitations include potential misunderstandings about array indexing and function parameter passing in C, as well as the need for clarity on the differences between struct member names.
mathmannn
I do not have much experience with C, just a single course a few years ago, and I didn't do so well in it either.
I'm just trying to get familiar with structs in C. Basically what I want to do is just store the length and width of a rectangle using a function and a struct.
I can get it to work without using a function with this code:
Code:
#include <stdio.h>
#include <stdlib.h>
typedef struct{
    int length;
    int width;
} Piece;
int main(void){
    int p_count=0;
    printf("How many pieces? ");
    scanf("%d",&p_count);
    Piece piece[p_count];
    for(int i=0; i<p_count; i++){
        printf("\n\nEnter the length for piece %d: ",i+1);
        scanf("%d",&piece[i].length);
        printf("Enter the width for piece %d: ",i+1);
        scanf("%d",&piece[i].width);
        printf("\n\n---------------------------\n");
        printf("Length for piece %d is: %d\n",i+1,piece[i].length);
        printf("Width for piece %d is: %d\n",i+1,piece[i].width);
        printf("---------------------------\n");
    return 0;
However, when I try to move just the part where I get the input into a function called "readPieces" I get an error when trying to store the values into length and width.
Code:
#include <stdio.h>
#include <stdlib.h>
typedef struct{
    int length;
    int width;
} Piece;
void readPieces(Piece piece, int p_count);
int main(void){
    int p_count=0;
    readPieces(piece[p_count],p_count);
    return 0;
void readPieces(piece[p_count], int p_count){
        scanf("%d",&piece[i].len);
        scanf("%d",piece[i].wid);
I'm sure that my mistake is something about how I call the function, or how I'm trying to store the values. But I do not have enough experience to debug this myself.
If anyone can help out with understand the proper way to call a function using a struct and store user input it would be greatly appreciated.
What kind of error?
Code:
and
Code:
are not exactly identical.
piece[p_count] is an attempt to access beyond the end of the array.
Try this:
Code:
    readPieces(piece, p_count);
void readPieces(PIECE *piece, int p_count){
Borek said:
What kind of error?
Code:
and
Code:
Sorry I forgot to change that. Originally I had it as &piece.len but changed to .length just for the post.
My error comes from Xcode, saying "The subscripted value is not a pointer, array, or vector" and it underlines &piece.length and also &piece.width
Try this:
Code:
Thank you SO much! This worked perfectly. If you wouldn't mind, could you explain what you mean by access beyond the end of the array? If p_count is just defined by the input, I can't seem to understand how could it be outside of the array.
11K
  • · Replies 17 ·
  • · Replies 19 ·
