Calculating the Field strength of a magnet at a certain distance
The discussion focuses on calculating the magnetic field strength (B) of a permanent magnet at a specific distance. It confirms that the field strength does not follow the inverse square law but rather decreases approximately as the inverse cube of the distance from the magnet's center when measured far away (greater than five times the magnet's greatest dimension). The equations provided, such as F = BIL(sinθ), can be used for measuring the magnetic field strength, although practical difficulties exist. The conversation also touches on the effects of cutting a magnet and the constants associated with different permanent magnet materials.
  • Understanding of magnetic field concepts
  • Familiarity with the equations of electromagnetism
  • Knowledge of measuring instruments like ammeters and voltmeters
  • Basic principles of force and motion
  • Research the inverse cube law in magnetism
  • Learn about Hall probes for measuring magnetic field strength
  • Investigate the properties of different permanent magnet materials
  • Explore practical applications of measuring magnetic fields using current-carrying wires
Physicists, engineering students, hobbyists in magnetism, and anyone interested in measuring and understanding the properties of permanent magnets.
kaikalii
Is there a way to calculate the magnetic field strength, B, of a magnet (permanent magnet, not an electromagnet) at a certain distance? I assume it follows the inverse square law, but other than that, I do not know what to do.
Tools I have available:
  • permanent magnet
  • ammeter/voltmeter
  • wire
  • batteries
  • spring scale
  • ruler
I am aware of the equations: F=8.99*109q1q2/r2, F=qVB(sinθ), and F=BIL(sinθ), but I do not know how I would use those to calculate the field strength with just the tools listed above.
Also, if you were to cut a magnet in half, would that half the strength of the magnetic field? Does every type of permanent magnet material have some kind of Tesla per meter2 per kilogram constant?
Do you really want to calculate the field? Your inclusion of a list of tools suggests that you want to measure it.
The equations you have listed won't help you calculate the field strength at a distance from the magnet, though [itex]F = Bqv sin \theta[/itex] is the basis of the Hall probe for measuring the field strength, and [itex]F = BIL sin \theta[/itex] could also be used - with considerable practical difficulties - for this purpose. Your list of tools seems to be chosen with this last method (measuring the force due to the field on a current-carrying wire) in mind.
Close to the magnet the field will vary in a complicated way, partly dependent on the magnet's shape. Far from the magnet (say > 5 times the magnet's greatest dimension. e.g. length) I would expect the field to fall off roughly as the inverse cube of the distance from the centre of the magnet.
  • · Replies 41 ·
  • · Replies 198 ·
17K
