Effort Required to Overcome Inertia
  • Context: Undergrad
  • Thread starter Thread starter sriram123
    Inertia
The discussion focuses on calculating the effort required to overcome the inertia of a rotating ring supported by rollers. Key concepts include the use of the equations of motion, specifically s = ut + 0.5at², to determine acceleration when the mass, distance, time, and initial velocity are known. Participants clarify that inertia itself does not need to be "overcome" but rather understood through the relationship defined by Newton's second law, F = ma, and the torque equation τ = Iα for rotational motion. The conversation emphasizes the importance of distinguishing between linear and rotational dynamics when analyzing forces.
  • Understanding of Newton's laws of motion, particularly F = ma
  • Familiarity with rotational dynamics, including torque (τ) and moment of inertia (I)
  • Basic knowledge of equations of motion for linear and rotational systems
  • Concept of friction and its role in motion analysis
  • Study the application of Newton's second law in both linear and rotational contexts
  • Learn about calculating torque and moment of inertia for various shapes
  • Explore the effects of friction on motion and how to calculate frictional forces
  • Investigate the dynamics of rolling motion and its differences from sliding motion
Students and professionals in physics, mechanical engineering, and anyone interested in understanding the principles of motion and forces, particularly in rotational systems.
sriram123
hi all,
This is a question regarding calculation of effort required to over come the inertia of a body.Let us have a ring(Some random example) which is supported by three rollers(Ring is sitting on the rollers).To rotate the ring,the applied effort has to overcome the friction and inertia of the body.The frictional force can be calculated using the coefficient of friction for line contact and the normal reaction (Weight of the body).But to calculate the force to overcome inertia mass of the body and the acceleration of the body has to be considered.This "acceleration " part that is quiet confusing to me.
How can I calculate the acceleration if I Manually push the ring.For example,I know how much distance I have to push(The circumference if I make one complete rotation),The time for rotation and that the initial velocity is zero(For first rotation).Can I use Equations of motion ( s=ut+0.5at^2) to find the acceleration which I can use in the Calculation of Inertial force?.
If I am too confusing,Simply put I want to know how to calculate the force required to overcome the inertia of a body If i know mass,distance to travel,time and initial velocity.
I am just trying to understand the concept so don't mistake me if i have misstated something.
Sorry for attaching a crappy image.I am on summer vacation and I only have paint installed in this computer(Even with paint many can do better but I can't)
Thanks in advance.
hi sriram123! :smile:
(btw, the image looks fine to me!)
sriram123 said:
… .But to calculate the force to overcome inertia mass of the body and the acceleration of the body has to be considered.This "acceleration " part that is quiet confusing to me.
(i assume you're only interested in rotating the ring, "on-the-spot"?)
please stop thinking about "overcoming the inertia"
there's no such thing as inertia … there's moment of inertia, and a couple of other phrases, but inertia on its own doesn't mean anything (or it just means "mass")
the mass isn't something that has to be "overcome" like a friction force or an energy threshold
a mass starts moving as soon as you push it (subject to friction etc)
the only equations you need are F = ma and τ = Iα :smile:
(and the standard constant acceleration equations, with θ ω and α instead of s v and a)​
The only equation you need to understand how force overcomes inertia is F=ma; and note that a is acceleration, which is the change in speed.
So no matter how large the mass or small the force, any net force will produce some acceleration. If the mass is moving at a constant speed the acceleration is zero so the net force is zero; if you're still pushing it to keep it moving then all of the force you're applying is exactly balancing the force of friction to end up with zero net force.
Your ring problem is a bit harder because it involves rotation so requires that you work with torque and the moment of inertia. Thus you might want to be sure that you understand the "effort required to overcome inertia" problem in the simpler case of a block sliding at a constant velocity on a flat surface with friction, before you take on the rotating ring.
  • · Replies 19 ·
  • · Replies 138 ·
9K
  • · Replies 60 ·
