Faraday's law and gauss's law for magnetism apparent contradiction
The discussion revolves around the apparent contradiction between Gauss's Law for magnetism and Faraday's Law of electromagnetic induction. Participants explore the implications of these laws in the context of closed and open surfaces, and how they relate to magnetic flux and electric fields.
  • One participant notes that Gauss's Law for magnetism states that the integral of the magnetic field B over a closed surface is zero, which raises questions about the implications for Faraday's Law, which involves a time derivative of this integral.
  • Another participant clarifies that Gauss's Law applies to closed surfaces, while Faraday's Law applies to open surfaces, suggesting that the two laws operate under different conditions.
  • A different viewpoint suggests that Gauss's Law pertains to surfaces without boundaries, whereas Faraday's Law relates to surfaces that can have boundaries, using the analogy of walking on different types of surfaces.
  • One participant argues that there is no contradiction, explaining that the time derivative of the integral in Faraday's Law must account for changes in the area over time, and that if the magnetic flux through a closed surface is zero at one time, it must remain zero at all times.
  • This participant also discusses the local form of Maxwell's equations, indicating that the divergence of the magnetic field must be zero, which aligns with Gauss's Law and suggests consistency between the two laws.
Participants express differing interpretations of the relationship between Gauss's Law and Faraday's Law, with some arguing that there is no contradiction while others question the implications of the laws. The discussion remains unresolved with multiple competing views.
Participants highlight the importance of distinguishing between closed and open surfaces in the application of these laws, and the discussion includes considerations of how time-dependent changes in area may affect the interpretation of Faraday's Law.
In Gauss's Law, the integral is over a closed surface, e.g. a complete sphere, cylinder, etc.
In Faraday's Law, the integral is over an open surface whose edge is the path used in the line integral of E on the other side of the equation. For example, the surface might be a hemisphere, whose edge is a circular path. The integral of B would be over the hemisphere, and the integral of E would be around the circular path.
If I understand correctly, Gauss's law is for a surface off which someone walking could never fall. Like the Earth for example.
Whereas Faraday's Law is for surfaces like when we thought the Earth was flat.
Is that correct?
There is, of course no contradiction, because a closed surface has no boundary, and thus for a closed surface [itex]A[/itex], you have
[tex]\int_A \mathrm{d}^2 \vec{F} \cdot \vec{B}=0.[/tex]
On the other hand there is Faraday's Law that reads for any surface [itex]A'[/itex]
[tex]\int_{A'} \mathrm{d}^2 \vec{F} \cdot \partial_t \vec{B}=-\int_{\partial A'} \mathrm{d} \vec{x} \cdot \vec{E}.[/tex]
You can take out the time derivative of the integral, but you have to take into account that there is a piece from the change of the area with time (if it's moving). In this form Faraday's Law reads
[tex]\frac{\mathrm{d}}{\mathrm{d} t} \int_{A'} \mathrm{d}^2 \vec{F} \cdot \vec{B}=-\int_{\partial A'} \mathrm{d} \vec{x} \cdot (\vec{E}+\vec{v} \times \vec{B}),[/tex]
where [itex]\vec{v}=\vec{v}(t,\vec{x})[/itex] is the velocity field of the area (including its boundary).
If [itex]A'=A[/itex] is closed, you have [itex]\partial A'=0[/itex], and thus the right-hand side vanishes. This means that if the magnetic flux through a surface vanishes at some time [itex]t_0[/itex], it must vanish at any time. This means Gauß's Law for the magnetic field (which says that there are no magnetic charges) is consistent with the dynamics of the magnetic field.
Of course, all this is much more simply stated for the local form of Maxwell's equations. Faraday's Law reads
[tex]\partial_t \vec{B}=-\vec{\nabla} \times \vec{E}.[/tex]
Taking the divergence of the whole equation leads to
[tex]\partial_t (\vec{\nabla} \cdot \vec{B})=0,[/tex]
which means
[tex]\vec{\nabla} \cdot \vec{B}=f(\vec{x})=\text{const in time}.[/tex]
According to Gauß's Law, which states that
[tex]\vec{\nabla} \cdot \vec{B}=0[/tex]
demands that [itex]f(\vec{x})=0[/itex]. So again we see that the two homogeneous Maxwell equations are consistent.
There is also a consistency condition for the inhomogeneous Maxwell equations. This gives the conservation law of the electric charge, i.e., the continuity equation
[tex]\partial_t \rho+\vec{\nabla} \cdot \vec{j}=0.[/tex]
