Particles connected to Antiparticles
The discussion revolves around the concept of particle-antiparticle creation, specifically focusing on whether there is any lasting connection between particles and their corresponding antiparticles in terms of their interactions. Participants explore theoretical implications, experimental observations, and the nature of virtual versus real particle pairs.
  • Some participants inquire about the nature of a "lasting connection" between particles and antiparticles, questioning if such a connection has been predicted or observed.
  • One participant suggests that charged particles are connected by electromagnetic force, noting that in electron-positron production, they move apart and interact with other particles.
  • Questions arise regarding how virtual electron-positron pairs, created under the Heisenberg uncertainty principle, find each other for annihilation.
  • Another participant argues that any antiparticle can interact with a particle, not just its corresponding antiparticle, and that the properties of the resulting photon account for differences in momentum and energy.
  • Discussion includes the distinction between virtual pairs created in vacuum and real pairs produced by gamma rays, with some participants asserting that both processes fundamentally operate similarly despite differences in energy availability.
  • Clarifications are made regarding the nature of virtual particles and their momentum, with references to quantum field theory and conservation laws governing particle interactions.
Participants express differing views on the nature of connections between particles and antiparticles, the implications of virtual versus real particles, and the mechanisms of annihilation. The discussion remains unresolved with multiple competing perspectives presented.
Participants reference the Heisenberg uncertainty principle and conservation laws, but there are limitations in the assumptions made about the interactions and definitions of virtual and real particles. The discussion does not resolve these complexities.
Crosson
Consider a particle-antiparticle creation, let's say an electron and a positron.
I am curious if there is any lasting connection* between particles and the antiparticles that they were born with (in terms of the physics of their interaction).
Has anyone ever predicted or observed such a lasting connection? Has it already been ruled out by experiment?
*In an E&M book I read, they mentioned the idea that charge particles were connected to their corresponding birth-antiparticles by a topological handle. Then electric field lines never end. (Imagine a smooth sphere with a handle, the points of contact between handle and sphere are what we call particles and antiparticles. Draw electric field lines on the handle as if those spots were the charges, and you will see what I am talking about).
What exactly are u suggesting through this ambiguous "lasting connection"...?And why do you provide a classical example,when it has nothing to do with particle-antiparticle theory...?
So,please reformulate your post as to remove ambiguity.
Daniel.
Charged particles in general are "connected" with other charged particles by em force. In electron-positron production, the particles go off in opposite directions and the positron is quickly killed by interacting with another electron.
If there is created a virtual electron positron pair and they have to annihilate after a time d(t) (Heisenberg's uncertainty principle). How does the electron find the positron?
Don't know anyone this question?
I think paritcles and antiparticles are the same except for the fact that the charges is the opposite w/ the antiparticles. go to www.cern.ch for an answer, they were the first to make antiparticles.
Fibonacci
"The" electron doesn't have to find "the" positron. Any antiparticle will do, the difference in momentum and energy will be folded into the properties of the resulting virtual photon.
The electron does not find the positron. There has to be this pair because there is just enough energy available to create such a pair. Also if there were no charge present prior to this creation then there must be a positron and an electron because of charge conservation.
regards
marlon
It needn't be a virtual photon.It can be very real.Light on light scattering proves it.
Daniel.
Daniel.
Only if enough energy was available prior to the actual virtual pair creation, which is indeed the case in your given example. Otherwise energyconservation would be violated.
marlon
thanks for answers.
Lets say (only imagine) there are only these 2 particles (anti particle and its particle). The other space is emtpy. And a particle has a lifetime of d(t) (HUP). How can they annihilate after this time. It seems not logically that they collide after d(t).
Sterj said:
thanks for answers.
Sterj,
Didn't i already explain this to you ?
They MUST 'collide' because they can only exist for this certain amount of time dt, predicted by the HUP.
Suppose the initial state has energy-value A and the final state has also energy-value A. In between those two states, the energy value A can become uncertain (dE) during a time-interval dt. that is what happens, during this dt there is more energy and thus, 'spectacular' things can happen, like the vacuum fluctuations. the term fluctuations really denotes the dE part of my explanation. The question as to whether the two virtual particles collide is not that important. All we know is that after a time dt they MUST BE gone and the energy that is left behind must be equal to the energy prior to the virtual pair creation because of energy conservation. Just look at my A ----> A example
regards
marlon
Besides, let me drive you more crazy with this...
The actual creation of the virtual pair can occur anywhere in space time, this is proven QFT. The annihilation can occur somewhere else on a very remote spot from where the creation occurred.
As a force carrier, a virtual particle carries a definite momentum value and due to HUP, it must be ANYWHERE in space time, the field expressing this particle is spread out over an infinite distance.
When the transported momentum-vector points from the emitting matter particle to the receiving matter particle, you have a repulsive force. When the momentum is pointed from the receiving particle to the emitting particle (momentum is transported backwards, if you will) you have an attractive force. In QFT a force is not F = ma, but it really is the transportation of a definite momentum-value
regards
marlon
thanks. @marlon: you can explain very well. thanks.
and also thanks to theother
One bit of confusion in the discussion so far is between (a) the virtual electron-positron production in the vacuum and (b) real electron-positron production by gamma rays (energy above 1.022 Mev) passing near nuclei, especially heavy (like lead). (a) is a result of Heisenberg's principle, while (b) is straightfoward quantum electrodynamics.
Elelectron-Positron pairs created in scattering experiments are correlated through standard conservation laws -- tightly if they are the only final state, loosely if other particles are involved in the final state.
For virtual pairs the same is true, except for energy -- they are governed by the free, not the exact Hamiltonian.
Regards,
Reilly Atkinson
But aren't these pairs on mass shell ? Therefore they cannot be virtual
regards
marlon
Yes indeed, however, these pairs are not virtual but they exist on their mass shell
marlon
To Marlon
regards
marlon
I specifically said they were real (not virtual). I don't understand your question.
mathman said:
To Marlon
Well, i was referring to the remark you made about the pairs created out of the vacuum and the pairs created by gamma rays...
Forget what i said about being on or off mass shell but what i don't see why you talk about confusion between these two options. I don't see no confusion and to be exact both processes inherently work the same. The only difference is the initial and final state but the actual electron-positron pair is always virtual an initio. In the second case, though, there is enough energy available so that this pair can become on mass shell and thus 'real' in terms of field theory. It's energy has no uncertainty...
regards
marlon
  • · Replies 28 ·
  • · Replies 21 ·
  • · Replies 36 ·
  • · Replies 18 ·
