| Thread Closed |
Vapor Density: 1.3 |
Share Thread | Thread Tools |
| Mar25-05, 06:03 AM | #1 |
Vapor Density: 1.3
For a solution It says; VAPOR DENSITY: 1.3
Is VAPOR DENSITY the same as Density of that solution? And what is the unit of 1.3? Hope for inputs. Thanks |
| Mar26-05, 02:45 AM | #2 |
Vapor density of 1.3 means, in my opinion, that this solution has 1.3 times more of that molecule in the gas phase than the solution in the equilibrium.
| Mar28-05, 10:36 PM | #3 |
Vapor density refers to the density of a vapor, in units such as g/m^3 or kg/m^3. Since you don't indicate any units, I think it means something different here. I found this URL:
http://www.trconsultinggroup.com/safety/oct2001.html According to that convention, your solution would produce a vapor with a density 1.3 times that of air. What IS the solution? Do you know? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Vapor Density: 1.3
| vapor density in kg/m3 in CO2 absorber | Classical Physics | 3 | ||
| vapor pressure | Classical Physics | 1 | ||
| water treatment plant vapor calculations | General Physics | 0 | ||
| Vapor Pressure | Biology, Chemistry & Other Homework | 1 | ||
| vapor pressure | Chemistry | 1 | ||
