How far is this definition of time correct?
  • Context: High School
  • Thread starter Thread starter aleemudasir
    Definition Time
The discussion revolves around the definition of time, specifically the assertion that time is a change in space. Participants explore various interpretations and implications of this definition, touching on concepts from Special Relativity and the nature of time measurement.
  • Some participants question the clarity of the initial definition of time as change in space, seeking a more general understanding akin to definitions of length, mass, and volume.
  • One participant cites Einstein's explanation of time in relation to simultaneous events and clock measurements, suggesting that time is fundamentally what a clock measures.
  • There is a distinction made between coordinate time and proper time, with some participants explaining that coordinate time indicates when an event occurs while proper time is the duration measured by a clock.
  • Time dilation is introduced as a concept where coordinate clocks do not necessarily run at the same rate as proper clocks, leading to confusion about simultaneity being observer-dependent.
  • One participant argues against the notion that coordinate time is merely the proper time of an arbitrary clock, emphasizing that coordinate clocks do not always keep proper time.
  • Another participant agrees that coordinate time is an abstraction but contends that it is not limited to defining inertial reference frames, citing examples from everyday use.
Participants express differing views on the nature of coordinate time and proper time, with no consensus reached on the implications of these definitions or their relationship to the initial question about time as change in space.
The discussion reveals limitations in understanding the definitions of time, particularly in distinguishing between coordinate and proper time, and the implications of these distinctions in different reference frames. Some assumptions about the nature of clocks and their measurements remain unresolved.
aleemudasir
How far is the definition of time that time is change in space, correct?
I'm not sure what you're asking.
Is this related to Special Relativity and the fact that different observers may have clock running at different rates?
No, I'm asking the general statement.
And I also wish to know what will happen in this case.
When I say general definition I mean, like the definition we have for length(measure of distance), mass(amount of matter), volume(space occupied) etc.
Time is what a clock measures. Here's how Einstein explained it in section 1 of his 1905 paper introducing Special Relativity:
If we wish to describe the motion of a material point, we give the values of its co-ordinates as functions of the time. Now we must bear carefully in mind that a mathematical description of this kind has no physical meaning unless we are quite clear as to what we understand by “time.” We have to take into account that all our judgments in which time plays a part are always judgments of simultaneous events. If, for instance, I say, “That train arrives here at 7 o'clock,” I mean something like this: “The pointing of the small hand of my watch to 7 and the arrival of the train are simultaneous events.”
It's very simple.
George maybe you should write an FAQ or something on it. This question does seem to pop up often even though the operational definition of time is quite clearly spelled out in relativity texts and the likes.
There are at least two types of time - coordinate time, and proper time. And sums and differences thereof, of course.
Coordinate time tells you WHEN something happens - usually the something is abstracted as "an event".
Proper time is a duration, usually described as "wristwatch time". It's measured by some acual clock. The clock can be abstractl specified by some worldline in space-time.
The confusing part starts to happen when one tries to explain that coordinate clocks don't necessarily run at the rate as real clocks, and that this is called time dilation.
MOre confusion tends to arise when one attempts to explain that "at the same time" is an observer dependent statement, often a coordinate-dependent one.
I think a lot of the confusion involves "unlearning" some pre-relativistic ideas about time.
Wow, I've never heard so many misstatements all in one place in a long time.
First off, Coordinate Time is an abstraction just like Coordinate Distance to permit us to define an Inertial Reference Frame (IRF) so that there are not any real coordinate clocks (or rulers) permeating all of space but if we wanted to actually put a real clock at a real coordinate location somewhere, it would keep Proper Time just like any other clock. The only difference between such a clock and some other clock that we might want to consider is that the "Coordinate Clock" must forever remain inertial which means it must remain at its coordinate location. We also set it one time to match the Coordinate Time and never set or reset it again.
But whatever scenario we want to envision in which we apply a real clock to match the Coordinate Time at some Coordinate Location, we can then apply the Lorentz Transformation process to create a new IRF moving with respect to the original one and end up with a new Coordinate Time definition in which there are no longer any clocks at any particular Coordinate Locations. It's in this sense that we never want to require that there be any real Coordinate Clocks. As Einstein said, they're imaginary.
We use the concept of an IRF then to describe and/or analyze how real clocks keep track of Proper Time but we always reserve the right to have these real clocks accelerate, in other words, they don't have to remain inertial at any particular location. Time Dilation then is the ratio of the passage of Coordinate Time to the passage of Proper Time and is a function of the instantaneous speed of the clock according to the particular IRF that we are considering.
Of course, measuring time is just like measuring distance: it is always a delta (or duration) between two points. We can always use a clock to measure a time interval and we can always use a stop watch (whose purpose is to measure a time interval) to measure what we regard as a clock time. Drawing a distinction between Proper Time and Coordinate Time with regard to one measuring duration and one measuring clock time is a red herring. Every clock has to be set at some point and then measures a delta time or duration.
And there is nothing confusing about "at the same time" if we simply point out that we mean Coordinate Time according to a chosen IRF.
It's not confusing. It's very simple. Sorry to be so blunt but I just can't let so many misstatements go unchallenged.
Isn't coordinate time just the proper time of some clock, that we can choose arbitrarily? In SR coordinate time is the proper time of a clock at rest in the reference frame that we have chosen. In GR we have to choose the position of the "coordinate clock" as well.
Not really, because coordinate clocks don't necessarily keep proper time :-(.
I didn't think anything I said was even mildly controversial!
I would agree that coordinate time is an abstraction. I would not, however, limit it to defining inertial reference frames. We use coordinate times every day in non-inertial reference frames - such as atomic time (also known as TAI time) on the Earth.
I'd agree that there aren't any real coordinate clocks permeating all of space, and I'd agree that if we put a real clock at a real coordinate location it would keep proper time. In fact, that's exactly what I said earlier.
This doesn't change the fact that a a real clock, placed on the Earth, will keep proper time and NOT remain in synch with the coordinate time standard. The real clock will keep proper time, and not coordinate time.
In general the rate of the real, physical clock needs to be adjusted (because it keeps proper time) when one wishes to define a coordinate time. This is routinely done with TAI time, the atomic clocks that define TAI time are rate adjusted by height above sea level before being averaged into the TAI time standard.
I thought this was well known, and totally noncontroversial, in case there's some remaining doubt, I'll post a reference from wiki:
http://en.wikipedia.org/w/index.php?title=International_Atomic_Time&oldid=550649840
In the 1970s, it became clear that the clocks participating in TAI were ticking at different rates due to gravitational time dilation, and the combined TAI scale therefore corresponded to an average of the altitudes of the various clocks. Starting from Julian Date 2443144.5 (1 January 1977 00:00:00), corrections were applied to the output of all participating clocks, so that TAI would correspond to proper time at mean sea level (the geoid). Because the clocks had been on average well above sea level, this meant that TAI slowed down, by about 10^−12. The former uncorrected time scale continues to be published, under the name EAL (Echelle Atomique Libre, meaning Free Atomic Scale).[10]
This may be true in the special case you were envisioning, but it's not true in general. Or should I say In General?
Coordinate time and coordinate time standards are an important part of everyday life. Drawing the simple distinction between "time as a coordinate" and "time as in interval" is a rather elementary, but I think important, step in understanding what we mean when we say "time". We use one word ("time") to talk about a family of different concepts ("coordinate time", "proper time"). These concepts, while related, are not identical. Becoming aware of the differences is , I think, important.
And that was the purpose of my post - to point out some of these differences. When we talk about time, sometimes we are talking about "proper time", and we are not rate-adjusting the clocks. Other times, we are talking about "coordinate time", and we ARE rate adjusting them.
It wasn't. My first reaction to the term "coordinate clock" was that it seems like a useless concept. I thought, why would we want a clock that measures coordinate time? But you explained that in your next post.
Pervect said that confusion arises as one tries to explain this, so he was clearly talking about how people who are new to relativity find this confusing.
Fredrik,i am new to relativity.
What is the difference between co-ordinate time and proper time?
Then which time is used to explain time dilation? Is it proper time?
Agreed, didn't see anything "wrong" with what you said.
The only way to get a better understanding of reality is to find a theory that makes accurate predictions about results of experiments, and then study the theory. A common objection is that since the theory isn't reality, understanding the theory is not the same thing as understanding reality. This is true, but it doesn't change the fact that studying a theory is the only way to get a better understanding of reality. We simply don't have "direct access" to reality. We only have "indirect access" to it, via theories.
So if you want to understand what time is, the best option you have is to make sure that you understand the mathematical definition of time provided to you by our best theory of space, time and motion. At present, this is general relativity. A definition of GR includes mathematical definitions of two kinds of time, "coordinate time" and "proper time". It also includes a correspondence rule that can be stated like this: If a clock displays t at one event and t' at another, then the proper time of the part of the clock's world line from the former event to the latter event is t'-t.
(A correspondence rule is an assumption about how to interpret the mathematics of the theory as predictions about results of experiments).
The old statement "time is what a clock measures" is not a definition of time in GR, or in any other theory. It's a theory-independent statement. It's a guiding principle about what sort of thing we should be calling "time" in theories of physics. It's a way of saying that every theory of motion should use the term "time" specifically for the mathematical concept that its correspondence rules associate with clocks.
So that old statement has its place, but it's not really a definition, or an insight about what time really is. It's just a pointer that tells you what you need to look at in an actual theory to get a better understanding of what time is.
Agreed, I have no formal education in SR, just from reading here and there, no textbook presentations.
This distinction took me quite a while to become more clear, even though it is "in your face" right from the first presentation of time dilation / differential aging.
Not surprising imo, that I never considered the proper time my watch measures is a separate concept from the age of the watch. (of course the two will always be the same for my watch, but not the always the case for spatially separated "things")
To your point of "un-learning" the idea the two are concepts are the same.
A coordinate system is a function that takes points in spacetime to 4-tuples of real numbers. If p is a point in spacetime (i.e. an event), and ##\phi## is a coordinate system defined on a set that includes p, then we can write ##\phi(p)=(t,x,y,z)##. The time coordinate of p in the coordinate system ##\phi## is just the number t. So coordinate time (i.e. the time coordinate) is a property of an event and a coordinate system. Change the coordinate system, and the time coordinate of p changes.
Proper time on the other hand is a property of a curve in spacetime. In SR, the definition can be stated in terms of the coordinates of some inertial coordinate system, by saying if p and q are events, then the proper time of a curve from A to B is the integral of ##\sqrt{dt^2-dx^2}## along the curve. This way of stating the definition is simple and easy to understand, but it hides the fact that the result of that integration is independent of what inertial coordinate system we're using, and it can make you think that you need to use some inertial coordinate system. This is not the case. The definition can be stated without mentioning a coordinate system at all. (It's just harder to understand that definition). So proper time is a property of a curve that doesn't involve coordinate systems in any way. Change the coordinate system, and the proper time of the curve doesn't change.
Proper time isn't defined for all curves. (There would be a problem if the thing under the square root isn't positive everywhere along the curve). But it is defined for all curves that can represent the motion of an object, like a clock.
Time dilation is about how two inertial coordinate systems in SR that take the same event to 0 assign different time coordinates to events on the time axis of one of the coordinate systems. So time dilation is about coordinate time. Problems involving time dilation can however often be solved by considering proper time instead. This is e.g. the fastest way to find the correct ages of the twins in the twin paradox.
Fredrik:
Oh no...just when I thought I had this straight in my mind.
I would have answered: Time dilation is about proper time: Two different observers record different elapsed [proper] times on their own clocks after starting out at some location, travel different paths, then rejoin later.
What's wrong with this??
I'm going to answer this in the context of inertial coordinates in Special Relativity (without gravity).
Proper time is measured by a single clock and can be used only for events that occur locally, right next to the clock.
Coordinate time allows you to measure events that are far apart in distance. To do so you can't use a single clock, you need multiple clocks, each located next to the event it is measuring. So imagine a whole network of clocks, all a fixed distance from each other, and all ticking at the same rate. The important issue is that you need to synchronise all these clocks to each other, and that's a non-trivial process. For inertial coordinates, there's an agreed way of doing this ("Einstein synchronisation"). Once you've done all that, the coordinate time at an event is determined by the nearest local clock within the network of clocks.
For time dilation, you compare the proper time on one clock that is moving relative to the network, against the coordinate time on the network of clocks.
Non-inertial coordinates
If the network of clocks is non-inertial, or if there is gravity, things get more complicated. In this case, clocks that are a fixed distance apart need not tick at the same rate ("gravitational time dilation"), so the clocks need to be adjusted to run fast or slow to remain synchronised. Also in this case there's no universally agreed method of how to synchronise your network clocks; many options are available.
Naty1 said:
Fredrik:
"different paths, then rejoin later."
Time dilation doesn't require them to rejoin. However the proper time comparison does. To "extend" your proper time to make measurements is coordinate time.
That said, I couldn't disagree that it is "about proper time".
That's the twin paradox, and as I said, the fastest way to find the correct ages of the twins is to calculate the proper time of their world lines. So there's nothing wrong with what you said.
What I mean by "time dilation" is just the fact that two inertial coordinate systems that send the same event to 0 (so that they're related by a Lorentz transformation) disagree about what time coordinates to assign to events on one of the coordinate systems' time axis. A Lorentz transformation sends (t,0) to (γt,-γvt), so the time coordinate is "dilated" by a of factor gamma. (I write the time coordinate first and the position coordinate second in these coordinate pairs).
So you can define time dilation without mentioning proper time, but I don't think there's a definition that doesn't mention inertial coordinate systems, or at least simultaneity. The problem is that we're talking about the ticking rates of two clocks that will be at the same place only at one event (assuming that they're doing inertial motion), so we will need one clock's notion of simultaneity to compare them.
DrGreg:
Nitsuj:
I find such descriptions confusing; Are we making MEASUREMENTS? maybe 'comparisons' is better.
I don't know how to express those ideas any better, but I do know:
my proper time is your coordinate time,
your proper time is my coordinate time,
[In other words, proper time is local time, coordinate time is spacetime interval distant]
nobody can 'measure' coordinate time,
Coordinate times can only calculated from the (proper-time) readings [measurements] of clocks via time dilation relationships.
For the OP: This might be helpful background:
http://en.wikipedia.org/wiki/Absolute_time_and_space#Impact_of_special_relativity
The concepts of space and time were separate in physical theory prior to the advent of special relativity theory, which connected the two and showed both to be dependent upon the observer's state of motion. In Einstein's theories, the ideas of absolute time and space were superseded by the notion of spacetime in special relativity, and by dynamically curved spacetime in general relativity.
So in SR relative speed affects comparative elapsed times; in GR different gravity potentials [curvatures of spacetime] also affect relative elapsed times...an additional effect on time and space. Unlike Newtonian physics, there is no universal absolute time.
That is indeed a correct description of the famous twin paradox in which the observers eventually rejoin. When they do they damn well better agree about which one has aged more; one head will have more gray hair than the other, meaning that it experienced more proper time.
But it's not a complete summary of the time dilation problem. Suppose the two observers never rejoin; they just travel in opposite directions at constant velocity forever. B says he is at rest while A is moving away from him, while A says that he's the one at rest and B is the one who is moving. Neither one experiences anything unusual with regard to their own clocks, but both conclude that the other clock is moving relative to them and is running slow. And they're both right.
That's a coordinate-time phenomenon. Think for a moment about what it means to say that one clock is running slower than another (or that the hair on one head is graying less quickly than the hair on another head). If the two clocks or heads are colocated, it's easy - you just compare them. But if they aren't? Then when I say that the other clock is running slow, I'm really saying something like: "At the same time that my clock read noon the other clock read noon; and at the same time that my clock read ten minutes past noon the other clock read only five minutes past noon". Now we have to ask what "at the same time as" means; and the answer is "has the same time coordinate as", so will change according to the coordinate system I choose.
Two subtleties here:
First, in special relativity, there's a natural coordinate system for me to choose, namely the one in which I'm at rest and my coordinate time is equal to my proper time, the proper time experienced by a clock at rest relative to me. Time dilation arises because other observers moving relative to me will find that in their most natural coordinate system their coordinate time is not equal to my proper time, it's equal to their proper time.
Second: In normal life where all the speeds are small compared to the speed of light and we don't have to worry about relativistic effects, when we speak of "time" we just about always mean coordinate time. In particular, any time we speak of two things happening "at the same time" but in different locations, we're using coordinate time, not proper time. It just so happens that because all the observers are more or less at rest relative to one another (even a speed of many tens of miles a second is near as no never mind at rest compared with the speed of light) everyone still manages to pretty much agree about when two events happen at the same time and when they don't.
what if a network of clocks are moving relative to another network of clocks?
If what you say is correct,then won't co-ordinate time of event measured by the one moving relative to observer change as proper time change?
Hmm. As far as I understand your classification scheme I would have put it as a correspondence rule of GR. Specifically, the correspondence rule for proper time. Am I missing some subtle point you are trying to make?
I prefer to think of time dilation as the ratio of coordinate time and proper time.
I wonder if the OP is still here...Did you get your question answered??
for the OP...I posted
It is worthwhile clarifying for someone starting out that whenever time is relative so is distance. There is no universal time, there is no universal distance. What is universal is the speed of light...at least locally.
This is codified in flat space time by the Lorentz transform..where space and time 'transform' between themselves according to relative motion. When one changes so does the other. My space and my time is not the same as your space and your time...some of my space may be part of your time...and vice versa...
Not only that, but if we are far enough apart such that the speed of light prohibits our communication of information, we share no space and maybe no time. Information is LOCAL analogous to proper time.
In GR, as I posted, curvature [gravitational ] also effects time...and therefore distance. In cosmology, for example, there are many spacetime curves between distant observers so 'distance' takes on some additional variations. That takes more complex math...the FRW metric...to determine.
Here is an animation that depicts proper and coordinate time...be prepared, it takes a few minutes to get oriented...to figure out what is being depicted...Be sure to scroll down so you can activate the animation from beneath the charts...
http://www.adamtoons.de/physics/gravitation.swf
  • · Replies 37 ·
High School Light & Time
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 20 ·
