Stern-Gerlach experiment with orthogonal spin detector
The discussion centers on the feasibility of embedding a spin-1/2 particle within an additional detector (S) that measures spin about the Y-axis while passing through a Stern-Gerlach apparatus designed for the X-axis. It concludes that if the detector S has no magnetic moment and measures at a fixed frequency F, the particle cannot collapse to a spin state about X while being measured for Y. The instantaneous nature of quantum collapse, as dictated by the Born rule, implies that the particle would not exhibit intermediate states and would pass through the Stern-Gerlach apparatus without deflection. The impracticality of such an experiment is highlighted due to the interaction of magnetic fields from both detectors.
  • Understanding of quantum mechanics principles, particularly spin-1/2 particles.
  • Familiarity with the Stern-Gerlach experiment and its implications for quantum measurement.
  • Knowledge of the Born rule and its role in quantum state collapse.
  • Basic concepts of magnetic fields and their interactions in quantum experiments.
  • Explore the implications of the Born rule in quantum mechanics.
  • Investigate the Stern-Gerlach experiment and its applications in quantum state measurement.
  • Learn about the behavior of polarized photons in quantum optics experiments.
  • Research the effects of magnetic fields on quantum particles and their trajectories.
Quantum physicists, experimental physicists, and students studying quantum mechanics who are interested in the complexities of quantum measurement and spin dynamics.
msumm21
Suppose we have a Stern-Gerlach apparatus through which we send spin-1/2 particles and subsequently measure their position. If a passing particle "collapses" to the spin up state about X, it moves "up" and is registered by detector U, otherwise it "collapses" to the spin down state about X and moves "down" and is found by detector D. Now I'm wondering if it's possible to embed the passing particles within another detector S which measures the spin about Y (orthogonal to X) without affecting the net EM field from the Stern-Gerlach magnets around the particle? So a particle along with an "attached" detector S would move through the Stern-Gerlach together. I also want to assume (1) the detector S itself has no magnetic moment (if that's possible) and (2) the detector S can be programmed to measure the spin about Y at a fixed frequency F.
If this setup is somehow feasible, I wonder what would happen when F is large? If we repeatedly measure the spin about Y I assume we must get an answer "up" or "down," but in that case it seems the spin cannot spend time in the states with spin up or down about X and hence it would go straight through the Stern-Gerlach, right? But is it possible for such a particle to go through a Stern-Gerlach detector and not "collapse" to the spin up or spin down state about X?
As far as quantum mechanics is concerned, the interaction that leads to a collapse must be considered instantaneous - there is no "in process" state. This is enforced by the way the mathematical formalism works: there's a "before" state, a bunch of possible "after" states, a rule (the Born rule) for calculating the probability of collapsing into one of the "after" states, but nothing about what happens in between.
Thus, your hypothetical is equivalent to performing spin measurements along different axes in rapid succession. The momentum transfer and hence the particle deflection also happens instantaneously. You could reasonably imagine that the particle is given a kick at the moment of collapse; inertia and the kicks from subsequent measurements will determine the trajectory from there.
In practice such an experiment is completely impractical because the magnetic fields from the two detectors will combine in a way that does something completely different from what you want. A more achievable thought experiment that comes to the same conclusion would use polarized photons passed through a succession of polarizing filters at different angles.
  • · Replies 16 ·
  • · Replies 43 ·
  • · Replies 24 ·
