Electric Flux on the surface of a sphere
The discussion focuses on calculating the net electric flux escaping the surface of a sphere containing a line charge distribution of 0.6m length with a charge density of 5C/m. The user applied Gauss's Law, leading to the equation ψ = 2ρr, resulting in a calculated flux of 50C. The user expressed uncertainty about the approach and sought clarification on the use of spherical coordinates for integration. The consensus emphasizes using Gauss's Law for a more straightforward solution.
  • Understanding of Gauss's Law in electrostatics
  • Familiarity with electric flux concepts
  • Knowledge of spherical coordinate systems
  • Basic principles of charge density and line charge distributions
  • Study the application of Gauss's Law in various geometries
  • Learn about electric flux calculations in spherical coordinates
  • Explore the relationship between charge density and electric field strength
  • Investigate surface integrals in electromagnetism
Students and professionals in physics, particularly those studying electromagnetism, as well as educators looking for practical examples of electric flux calculations involving spherical geometries.
NWNINA
I'm trying to figure out an equation for finding the net flux that abandons the surface of a sphere which contains a line charge distribution an a charge density. The problem is:
A line charge distribution of 0.6m long with a charge density equal to 5C/m, is contained inside a sphere with radius of 5m. Find the net flux that abandons the surface of the sphere.
What I have done is the following
ψ=DA
D= εE
ψ=εEA=ε(ρ/(2∏εr)(4∏r^2)
∴ψ =2 ρ r
ψ= 2(5C/m)(5m) = 50C
I really don't know if this is the correct approach. Any help would be great.
So I've decided to take a different approach
ψ= ∫∫∫ ρ rdrd∅dθ
not sure if i should use d∅ or dz. maybe the first one because it is spherical.
what limits should I use?
NWNINA said:
Im trying to figure out an equation for finding the net flux that abandons the surface of a sphere which contains a line charge distribution an a charge density. The problem is:
ψ=DA
D= εE
∴ψ =2 ρ r
Use Gauss's Law.
Calculating the flux directly by means of a surface integral will be a mess.
