Thought experiment involving spacetime curvature:
The discussion revolves around the concept of spacetime curvature in relation to mass, exploring theoretical implications of filling the universe with mass and its effects on time. Participants examine the relationship between mass, spacetime, and the nature of time, while addressing misconceptions and clarifying definitions.
  • Some participants propose that mass slows down time as it warps spacetime, but this is contested as being valid only in specific cases of static mass.
  • There is a discussion about the concept of time "standing still" for photons, with some arguing that this notion is misleading and that elapsed time does not apply to photons.
  • A question is raised about the implications of filling the universe with mass and whether this would lead to a complete warping of spacetime, with some asserting that the universe is already filled with low-density mass.
  • Participants clarify that the mass filling the universe is not static or isolated, which affects the understanding of spacetime curvature.
  • There is a discussion about the nature of mass and spacetime curvature, with some participants emphasizing that spacetime curvature can occur regardless of mass density.
  • One participant draws an analogy between the uniform treatment of air as low-density and the cosmological treatment of the universe, suggesting that large-scale averages can mask local non-uniformities.
Participants express differing views on the implications of mass on time and spacetime curvature, with no consensus reached on the interpretations of these concepts. Some points are clarified, but fundamental disagreements remain regarding the nature of time and mass in relation to spacetime.
Limitations include the dependence on definitions of time and mass, as well as the assumptions regarding static versus dynamic mass distributions. The discussion does not resolve the complexities of these relationships.
VeryConfusedP
Peter Donis and Nugatory taught me a lot about spacetime curvature yesterday, but it has left me with so many questions.
It sounds like mass slows down time as it warps spacetime. So, I suppose this means: more mass = more spacetime curvature = less time elapsing.
Okay, in addition to that, we know that time "stands still" for the photon. I'm sure there's a more elegant way of putting this, and please let me know.
Here's my question: if--this is a big, big if--you could fill the known universe with mass, which, I suppose, would be a complete warping of spacetime, would time be nonexistent, as it is for the photon?
I know there's not enough mass and energy to do this, so you could immediately dismiss this course of thought, but I'm trying to get a better understanding of the reach of spacetime curvature.
However, if the universe (even in our ideal universe with as much mass as we need) cannot be filled completely with mass (which, again, is complete warping of spacetime), what is it about space or spacetime that prohibits this? Is there some interaction between spacetime and matter that demands that there should always be more spacetime than matter?
I think the obvious answer is: matter cannot be created or destroyed, and space is expanding. But I'm just trying to understand that a little better.
Thank you for your time.
This is not generally valid, because in the general case there is no way of defining what "slows down time" means. In the special case of a *static* mass, i.e., a mass that can be viewed as an isolated, unchanging object surrounded by empty space, then we can usefully define what "slows down time" means.
Again, this is not generally valid; it is only valid in the particular case of a static, isolated mass. In that case, yes, a larger mass will cause more "slowing down of time" at a given distance from the mass.
No, we don't know that. What we know is that the concept of "elapsed time" doesn't make sense for a photon. That's not quite the same thing.
(Yes, I know a lot of popular presentations say "time stands still for a photon", or words to that effect. That's an example of why you can't use popular presentations if you actually want to learn physics.)
It's not a big if; it's actually the case. The universe, to a first approximation, is filled with mass--very, very low density mass, but mass nonetheless. It's hard for us to see this on ordinary distance scales because at those scales the universe is obviously lumpy, not uniformly dense; we have dense objects like the Earth or the Sun or white dwarfs or neutron stars surrounded by what seems to be empty space. (Actually it isn't quite empty; estimates of the density of interstellar space are something like one hydrogen atom per cubic meter. But that's as good as empty for ordinary purposes.) But on a distance scale of a billion light years or so, which is the distance scale of interest for cosmology, all that lumpiness averages out, and we can treat the universe, to a first approximation, as just being uniformly filled with very low density mass.
No, it wouldn't, because the mass filling the universe is not static or isolated, so it doesn't work the way a static, isolated mass works.
No.
As noted above, this is incorrect.
Both of these are true, but I think you need to re-think how they are connected to the rest of your understanding, in the light of my comments above.
So, Peter, are you saying that curvature of spacetime can be understood as the curvature of low-density mass?
If the mass is low density, sure (except that it's not the mass that is curved, it's spacetime). Mass doesn't have to be low density--nor does it have to be high density. It can be either. It produces spacetime curvature either way.
You probably think of the air in a room as a substance of uniform and low density - and indeed it is, at any non-microscopic scale. But at a sufficiently small scale, the density in very non-uniform; essentially all of the mass of the air is concentrated in tiny particles (atomic nuclei) as dense as the interior of a neutron star and separated by enormous gulfs of empty space. Nonetheless, on any large scale it makes sense to treat air as a gas of uniform and low density.
Cosmologists are doing the same thing when they treat the universe as if it is filled with a uniform low-density mass; at the scale they're working with the star-sized and galaxy-sized lumps average out.
  • · Replies 31 ·
  • · Replies 29 ·
  • · Replies 25 ·
  • · Replies 52 ·
