Will a Sun Collapse Form a Black Hole?
Ahmed Samra
When the sun is collapsed will it form a black hole?
No, it is not massive enough. It will end up as a white dwarf.
When the sun is beginning to collapse will it get smaller and denser?
Yes it will until some backpressure will kick into stop further collapse , in large stars this backpressure can't fight back the huge mass so the gravity wins and the whole mass and all the leftovers collapse into a black hole but in mass that are smaller than the minimum limit to form a black hole they don't collapse to a black hole because the mass is not big enough for gravity to take over the pressures exerted by atoms in the case of white dwarfs - electrons.
http://en.wikipedia.org/wiki/White_dwarf
read about them.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
