Magnetic Flux and Induced EMF at South Pole
The problem involves calculating magnetic flux and induced electromotive force (emf) related to a metal sled at the South Pole, where the magnetic field strength is given. The sled's orientation changes from horizontal to vertical, prompting questions about the implications for magnetic flux and induced emf.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of magnetic flux using the equation Phi = BnA and question the angle between the magnetic field and the sled's surface. There is uncertainty about whether the flux is zero when the sled is vertical and how to approach the derivative for induced emf.
Participants are exploring different interpretations of the problem, particularly regarding the angle and the calculation of flux and induced emf. Some guidance has been offered about considering the flux before and after the sled's flip and the importance of including the area in calculations.
There is a lack of detailed information about the flipping process, which may affect the calculations. Participants are also navigating the constraints of homework rules regarding the provision of complete solutions.
m00nbeam360
The magnetic field strength at the South Pole is around 66μT, and magnetic field lines point out of the Earth perpendicular to the surface. The sled is a metal square of side 0.95 m (with non-conducting wooden slats in between).
What is the magnetic flux through the sled sitting flat on the ground?
Imagine that you accidentally flip the sled from horizontal to vertical in 0.65 s. What is the induced emf in the sled as a result of that motion?
B = 0.66 x 10^-3 T + z direction
A = (0.95m)^2 = 0.9025 m
θ = 90° (?)
Phi = B * nA = BAcosθ = BnA
ε = -dPhi/dt
I tried using the flux equation with cos(90), but since that's 0, would the flux really be 0?? Or is it just B*A?
Same problem with induced emf, but how do I calculate the derivative?
Thanks!
The angle between the magnetic field and the normal direction of the area is 0, not 90°.
B*A, right.
As we don't have details about the process, just consider the flux before and after the flip, and how quick it happens.
If the sled is flat on the ground, and the field lines perpendicular to the surface, then the flux will simply be the area of the sled X B. As you point out, ε = -dPhi/dt . When the sled is vertical, there is no field lines passing through the sled. It takes .65 sec to flip. This enough hints??
Thanks for the help! So is it really just (5.957 * 10^-4 Wb/m^2)/ (0.65 s)? Seems too easy.
Don't forget the area, otherwise the units do not match.
