What causes the transparency of glass?
  • Context: High School
  • Thread starter Thread starter RohitRmB
    Glass Transparent
The discussion centers around the question of why glass is transparent, exploring the underlying physical principles, atomic structure, and the behavior of light in relation to different materials. Participants delve into concepts such as electron energy bands, absorption of light, and the differences between glass and other materials like sand.
  • Some participants express confusion about the transparency of glass, questioning how light can pass through despite the presence of atoms and potential gaps.
  • One participant explains that light can be absorbed or transmitted based on its energy relative to the energy levels of electrons in the material, noting that glass blocks UV light while allowing visible light to pass through.
  • Another participant mentions that the transparency of solids, including glass, is related to the energy band structure and the inability of visible light photons to excite electrons due to insufficient energy levels.
  • There is a distinction made between glass and sand, with a participant clarifying that while sand consists of separate grains, each grain behaves according to its composition and band energies.
  • One participant raises a question about the behavior of light when it interacts with rapidly cooled materials, expressing uncertainty about how light travels through glass without loss.
  • A suggestion is made to consult additional resources for a more comprehensive understanding of optical transport in solids.
Participants do not reach a consensus on the explanation of glass transparency, with multiple competing views and ongoing questions about the underlying principles and behaviors of light in different materials.
Some discussions involve complex concepts such as electron band theory and the interaction of light with materials, which may not be fully resolved or understood by all participants. There are references to external resources for further exploration of these topics.
RohitRmB
I am not able to understand why is glass transparent because the same amount of atoms are still present and even if they are not able to arrange themselves in a proper crystalline structure then to there will some places where their would be less gap and some places where there is more gap for light to be able to pass through!
Hi RohitRmB! :smile:
RohitRmB said:
… there will some places where their would be less gap and some places where there is more gap for light to be able to pass through!
Light isn't bothered about where the gaps are.
(after all, light slows down even when it does "go through the gaps")
Light can be absorbed (and re-emitted in a different direction perhaps) even when it "goes through the gaps" if it has the right energy (ie the right wavelength) to be absorbed,
but will pass straight through if it does not have the right energy to be absorbed …
The electrons in different materials vary in the range of energy that they can absorb. Most glasses, for example, block ultraviolet (UV) light. What happens is the electrons in the glass absorb the energy of the photons in the UV range while ignoring the weaker energy of photons in the visible light spectrum.​
see http://en.wikipedia.org/wiki/Transparency_and_translucency for details :wink:
I don't understand it either. As far as I can tell, there is no simple answer. You have to do some very complicated math and that's what drops out. Or so I gather.
No, it is not that hard to understand, at least on some conceptual level.
In every solid electrons can occupy so called bands of different energy. There are two bands - one called valence band, occupied by electrons strongly attached to their atoms/molecules, and conduction band in which electron can freely move throughout the solid. Conduction band always contains electrons of a higher energy. (Compare http://hyperphysics.phy-astr.gsu.edu/hbase/solids/band.html)
Light doesn't get absorbed by solids just because, it gets absorbed when it can excite an electron from one band to another (the photon energy gets into exciting the electron). Whether light can get absorbed by a solid depends on band energy levels (or more precisely, on the energy difference between these levels). In some substances the distance between bands is such that visible light photons can't excite the electrons - they have too low energy. In effect visible light photons go through these substances without problem. Glass is an example of such a substance - which is why it is transparent.
Also note that glass doesn't have to be transparent, as technically glass means any solid which is amorphous (doesn't have a crystalline structure) and undergoes glass transition when heated. What I wrote above explains why SOLIDS are transparent, regardless of whether they are glasses or not (think calcite crystals).
OK. So what's the difference between glass and sand?
Sand is not a continuous solid, but every grain of sand separately will behave exactly the way I described. Depending on its exact composition and band energies it will either allow the light to pass through, or not.
When the material is suddenly and rapidly cooled then the atoms inside doesn't get enough time to arrange itself but wherever and however they may be arranged, when light falls on it there would be some light that would get refracted, some would diffract, some photons which strike the nucleus would bounce back. so how come there is no loss when light passes through glass!
i am not able to imagine that how light will light actually travel.
You might want to start by reading our FAQ subforum, and in particular, this entry:
https://www.physicsforums.com/showthread.php?t=511177
It presents a naive view of optical transport in solids, but at the very least, it introduces the importance of the material itself, the collective phenomena that do not exist in isolated atoms, and the complexities of optical transport.
Zz.
  • · Replies 19 ·
  • · Replies 22 ·
10K
  • · Replies 36 ·
13K
