Normalizers and normal subgroups.
  • Context: Graduate
  • Thread starter Thread starter Artusartos
    Normal
The discussion revolves around the properties of normal subgroups and normalizers within group theory, specifically examining the relationship between two subgroups H and K of a group G. Participants explore the implications of the equality of products of subgroups (HK = KH) and the conditions under which one subgroup is contained in the normalizer of another.
  • One participant asserts that if H is a normal subgroup of G, then HK = KH, and questions whether this implies H is contained in N(K), the normalizer of K.
  • Another participant challenges the assertion that HK = KH implies H ⊆ N(K), arguing that the latter is a stronger statement than the former.
  • This participant clarifies that HK = KH means that for each h in H and k in K, there exist elements h' in H and k' in K such that hk = k'h'.
  • They further explain that H ⊆ N(K) would require that for each h in H and k in K, there exists a k' in K such that hk = k'h, which is a more restrictive condition.
  • A later reply suggests that while the initial participant thought the two statements might be equivalent, they should seek a counterexample in small nonabelian groups to clarify the relationship.
Participants do not reach a consensus on whether HK = KH implies H ⊆ N(K). There are competing views on the strength of the implications of these statements, and the discussion remains unresolved.
Participants acknowledge potential limitations in their reasoning and suggest exploring specific examples to clarify the relationship between the statements discussed.
Artusartos
If G is a group with subgroups H and K, and if H is normal, then HK=KH, right?...Since we know that N(H) = G. However, since H commutes with K, then H must also be contained in N(K), right?...Since N(K) is the set of elements that commute with K...but I was a bit confused, because we know that, for any subgroup M, GM=MG. So G must be contained in the normalizer of any subgroup, right? But that doesn't make sense, since the normalizer of any subgroup would then need to equal G and every subgroup would be normal...I know I'm probably missing something, but I'm not sure what. So I was wondering if anybody could clarify this for me.
Thanks in advance
I don't see why ##HK=KH## would imply that ##H\subseteq N(K)##.
You seem to think that from ##HK=KH## follows that for each ##h\in H## holds that ##hK=Kh##. The latter seems like a much stronger statement.
The statement ##HK=KH## implies to me that for each ##h\in H## and ##k\in K##, there exists a ##h^\prime\in H## and ##k^\prime \in K## such that ##hk=k^\prime h^\prime##.
The statement ##H\subseteq N(K)## implies that for each ##h\in H## and ##k\in K##, there exists is a ##k^\prime \in K## such that ##hk=k^\prime h##. So this statement is the previous statement, but with the additional fact that ##h^\prime = h##. This seems like a much stronger statement to me.
Ok thanks, I didn't realize that...
Maybe it is true that the two statements are equivalent. I just said that it looks like a stronger statement to me, but stronger statements can sometimes be proven equivalent. To conclusively end this discussion, you should look for a example where ##HK=KH##, but where ##H## is not a subset of ##N(K)##. Try your favorite small, nonabelian groups and maybe you'll find one.
