Electric and magnetic field problems (curl/divergence)
The discussion focuses on solving electromagnetic field problems, specifically finding a magnetic field B that satisfies the equation \(\partial_t B + \nabla \times E = 0\) given the electric field \(E(t,x,y,z) = A \cos(ky - wt) \hat{k}\). Participants clarify the use of the curl operator and the correct formulation of the matrix for calculating \(\nabla \times E\). The discussion also emphasizes the importance of understanding the relationships between the electric and magnetic fields, particularly the condition \(\nabla \times B = \mu_{0} \epsilon_{0} \frac{\partial E}{\partial t}\).
  • Understanding of vector calculus, specifically curl and divergence operators.
  • Familiarity with electromagnetic theory, particularly Maxwell's equations.
  • Knowledge of matrix determinants and their application in vector operations.
  • Basic understanding of wave equations in physics.
  • Study the derivation and applications of Maxwell's equations in electromagnetic theory.
  • Learn about the physical significance of curl and divergence in vector fields.
  • Explore the relationship between electric and magnetic fields in wave propagation.
  • Investigate the implications of the constants \(\mu_{0}\) and \(\epsilon_{0}\) in electromagnetic equations.
Students and professionals in physics, particularly those focusing on electromagnetism, electrical engineers, and anyone studying wave phenomena in electric and magnetic fields.
ParoxysmX
Consider the electric field E(t,x,y,z) = Acos(ky-wt)k
1. Find a magnetic field such that [itex]\partial_t[/itex]B + [itex]\nabla[/itex] X E = 0
2. Show that [itex]\nabla[/itex] . E = 0 and [itex]\nabla[/itex]. B = 0
3. Find a relationship between k and w that enables these fields to satisfy
[itex]\nabla[/itex] X B = [itex]\mu_{0}[/itex][itex]\epsilon_{0}[/itex][itex]\frac{\partial E}{\partial t}[/itex]
Really the problem here is the first one. I understand (sort of) the curl operator, but how do you find [itex]\nabla[/itex] X E? Would you start with a matrix of
[i j k
0 kAcos(ky-wt) 0
0 0 Acos(ky-wt)]
Then find the determinant, which is Acos(ky-wt)(1+k)i - 0j + 0k?
No, that matrix is not correct. The cross product of the del operator [itex]\nabla[/itex] and a vector function is just an alternate convention for denoting curl. You can why here: http://en.wikipedia.org/wiki/Del#Curl. This should also explain why divergence can be denoted: [itex]\nabla \cdot[/itex]
So your matrix should be: [itex]\left[ \begin{array}{ccc}<br /> \hat{i} & \hat{j} & \hat{k} \\<br /> \frac{\partial}{\partial x} & \frac{\partial}{\partial y} & \frac{\partial}{\partial z}\\<br /> 0 & 0 & {\scriptsize A\cos(ky-wt)} \end{array} \right][/itex]
The rest of the problem should be relatively trivial once you know what the operators do.
Ah I see. Thanks for your help.
