Neutron Diffusion Equation/Spherical Geometry Source Problem
The discussion focuses on solving the 1D neutron diffusion equation in a finite sphere with a uniformly distributed source emitting S0 neutrons/cc-sec. The governing differential equation is given by \frac{1}{r^2} \frac{d}{dr} r^2 \frac{d\phi}{dr} - \frac{1}{L^2}\phi(r) = \frac{-S_0}{D}, with boundary conditions \phi(r=R) = 0 and \lim_{r \to 0} \phi(r) = finite. The correct solution involves hyperbolic functions, specifically \phi(r) = \frac{C_1}{r}sinh(\frac{r}{L}) + \frac{C_2}{r}cosh(\frac{r}{L}) + \frac{S_0L^2}{D}, ensuring the flux profile remains finite at the center of the sphere.
  • Understanding of neutron diffusion theory
  • Familiarity with differential equations, particularly boundary value problems
  • Knowledge of hyperbolic functions and their properties
  • Experience with numerical methods for solving differential equations
  • Study the application of boundary conditions in finite geometries
  • Learn about hyperbolic functions and their role in differential equations
  • Explore numerical methods for solving the neutron diffusion equation
  • Investigate L'Hôpital's rule and its applications in limit problems
Students and professionals in nuclear engineering, physicists working with neutron transport, and anyone involved in computational modeling of diffusion processes in finite geometries.
deebrwnfn11
Solve for the flux distribution using the 1D neutron diffusion equation in a finite sphere for a uniformly distributed source emitting S0 neutrons/cc-sec.
My problem right now is that I can't figure out the boundary conditions for this problem. We usually work with point sources in infinite domains when working with spherical geometry, so I am unfamiliar with setting up boundary conditions for finite spheres.
The governing differential equation is:
[itex] \frac{1}{r^2} \frac{d}{dr} r^2 \frac{d\phi}{dr} - \frac{1}{L^2}\phi(r) = \frac{-S_0}{D}[/itex]
with a boundary condition:
[itex] \phi(r=R) = 0[/itex]
This problem is going to be turned into a computer code, so we were told not to use extrapolated boundary conditions. I just need help finding the boundary condition for r = 0
As I mentioned above, we've never worked with finite spheres before so I am not 100% certain that the solution involves sin and cos. Maybe sinh and cosh?
[itex] \phi(r) = \frac{C_1}{r}sin(\frac{r}{L}) + \frac{C_2}{r}cos(\frac{r}{L}) + \frac{S_0L^2}{D}[/itex]
Physically, I know that the flux profile will be flat at the center of the sphere. I can't impose that the derivative equals zero because that would lead to a zero as the denominator in the coefficient terms. I've considered using a limit as r → 0, but that would cause the coefficient terms to shoot up to infinity. I don't think I can say that the neutron current at the center is equal to some value because there is a distributed source.
I am completely lost in finding this boundary condition. I think what I have written so far for the equations is right. If someone could point me in the right direction, or enlighten me of a mistake I have made I would be forever grateful.
Why do you need a boundary condition for r = 0? Isn't r = 0 within the sphere? Why isn't the BC Phi = 0 at r = R sufficient?
Obviously, you can substitute your trial function Phi(r) into the differential equation and see if the DE is satisfied. Have you tried this?
I did check my trial function by plugging it into the original ODE and it didn't take me long to figure out that it wasn't going to satisfy it. So I dusted off the old Differential equations textbook and found out what I was doing wrong. The actual solution is:
[itex] \phi(r) = \frac{C_1}{r}sinh(\frac{r}{L}) + \frac{C_2}{r}cosh(\frac{r}{L}) + \frac{S_0L^2}{D}[/itex]
with the boundary conditions [itex]\phi(r=R) = 0[/itex] and [itex]\lim_{r \to 0} \phi(r) = finite[/itex]
I reconsidered using the limit boundary condition after re-remembering L'hopital's rule. So my flux (with coefficients solved for) is:
[itex] \phi(r) = \frac{-S_0L^2R}{rDsinh(\frac{R}{L})}sinh(\frac{r}{L}) + \frac{S_0L^2}{D}[/itex]
Thank you for suggesting that I check my solution, I often forget to do that when I'm solving differential equations.
