Register to reply
Youngs Modulus Calculation
by ar202
Tags: calculation, modulus, youngs
Share this thread:
ar202
#1
Apr30-13, 06:20 PM
P: 45
I've got a beam of Length 500mm under third point loading.
width = 100mm depth=100mm
Force at rupture is 6.627kN
change in length =0.000019m = 0.019mm
can someone help me with the Youngs modulus please
i'm getting 6.87 GPa... which seems a bit low for concrete? Although possible as i cast it myself!
Phys.Org News Partner Engineering news on Phys.org
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
New filter technology uses inert gas to bore holes in high-quality steel
PhanthomJay
#2
May1-13, 03:14 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 6,040
I am not sure how you are arriving at this figure, but regardless, if you are looking at rupture load deflection, you are not going to get Youngs modulus, you will get a rupture modulus.
Concrete does not behave elastically except for reasonably low levels of stress and strain. When you approach rupture load, the stress strain relation is far from linear, and curves and flattens out considerably.
If you want Youngs modulus, you need to use smaller values of load in varying increments, and calculate it by using the deflection formula for a simply supported beam under mid point load. At higher values of load, you get a secant modulus, which is different.
ar202
#3
May1-13, 04:06 PM
P: 45
Quote Quote by PhanthomJay View Post
The smalles load value i have is 0.33kN and a deflection of 0.011mm which still gives me a pretty low value of E... 9GPa i think.
ar202
#4
May1-13, 04:42 PM
P: 45
ps thank you for your reply, i've run it through various values and its jumping from 9 to 30GPa. so i think ill take the 30 and run!
Register to reply
Related Discussions
Youngs modulus Introductory Physics Homework 5
Youngs modulus Introductory Physics Homework 4
Youngs modulus Introductory Physics Homework 2
Youngs Modulus and Elastic Modulus Introductory Physics Homework 6
Youngs modulus... Introductory Physics Homework 1
