Nabla calculus and conservative forces
The discussion centers on demonstrating that the magnetic force is conservative only when the time derivative of the magnetic field, dB/dt, equals zero. The key equation used is F=q[E+(v×B)], with the condition for conservativeness defined as ∇×F=0. The participant attempts to manipulate the equation ∇×[E+(v×B)] and applies Maxwell's equation ∇×E=-∂B/∂t to derive necessary conditions for conservativeness. The algebraic complexity arises when trying to simplify the expression v(∇⋅B)-B(∇⋅v)+(B⋅∇)v-(v⋅∇)B=0.
  • Understanding of vector calculus, specifically curl and divergence operations.
  • Familiarity with Maxwell's equations, particularly ∇×E=-∂B/∂t.
  • Knowledge of magnetic force equations, including F=q[E+(v×B)].
  • Basic proficiency in algebraic manipulation of vector fields.
  • Study the implications of dB/dt=0 on magnetic fields and conservative forces.
  • Explore vector calculus identities, particularly ∇×(A×B) and its applications.
  • Investigate the physical significance of magnetic fields not influencing particle speed and energy.
  • Review examples of conservative and non-conservative forces in electromagnetism.
Students and professionals in physics, particularly those studying electromagnetism, vector calculus, and the properties of conservative forces in magnetic fields.
KayDee01
1. The problem statement
I'm trying to show that the magnetic force is only conservative if dB/dt=0
F=q[E+(v[itex]\times[/itex]B)]
Conservative if ∇[itex]\times[/itex]F=0
∇[itex]\times[/itex](A[itex]\times[/itex]B)=A(∇[itex]\cdot[/itex]B)-B(∇[itex]\cdot[/itex]A)+(B[itex]\cdot[/itex]∇)A-(A[itex]\cdot[/itex]∇)B
Maxwells equation: ∇[itex]\times[/itex]E=-∂B/∂t
So the magnetic force field is conservative if
∇[itex]\times[/itex][E+(v[itex]\times[/itex]B)]=0
=∇[itex]\times[/itex]E+∇[itex]\times[/itex](v[itex]\times[/itex]B)
=-∂B/∂t+v(∇[itex]\cdot[/itex]B)-B(∇[itex]\cdot[/itex]v)+(B[itex]\cdot[/itex]∇)v-(v[itex]\cdot[/itex]∇)B
So from here I know that I need to show:
v(∇[itex]\cdot[/itex]B)-B(∇[itex]\cdot[/itex]v)+(B[itex]\cdot[/itex]∇)v-(v[itex]\cdot[/itex]∇)B=0
But when I write it out in all its components I get lost in the algebra. And then it got me thinking, if that equals zero, why doesn't ∇[itex]\times[/itex](A[itex]\times[/itex]B) always equal zero.
I know there's a simple answer to this as we did it in lectures but I can't seem to find it in my notes anywhere.
You cannot assign a scalar potential to the magnetic field. You can show that the magnetic field does not influence the speed (and therefore the energy) of the particle, however. This is related to ##\vec{v} \cdot \vec{F}##.
