Where Do the Two Electrons Go During Alpha Decay?
  • Context: Graduate
  • Thread starter Thread starter JMP1961
    Binding energy Energy
The discussion revolves around the process of alpha decay, specifically focusing on the fate of electrons during the decay of radium 226 into radon 222 and the implications for calculating binding energy. Participants explore the relationship between atomic and nuclear masses and the treatment of electrons in these calculations.
  • One participant questions the whereabouts of the 88 electrons originally present in radium 226 after the alpha decay process, suggesting confusion about their accounting in binding energy calculations.
  • Another participant proposes that the electrons' binding energies are negligible compared to nuclear energies, implying they are often not included in such calculations.
  • A different participant clarifies that atomic masses include electrons, while nuclear masses do not, and notes that for alpha decay, using atomic masses is acceptable since the number of electrons remains constant before and after the decay.
  • One participant highlights that alpha particles, being positively charged, are highly ionizing and may strip electrons from nearby atoms after being emitted.
Participants express uncertainty regarding the treatment of electrons in binding energy calculations, with some agreeing on the negligible impact of electron mass, while others raise questions about their fate post-decay. The discussion does not reach a consensus on the implications for binding energy calculations.
There is a distinction between atomic and nuclear masses that is relevant to the discussion, as well as the assumption that the binding energies of electrons can be disregarded in certain decay calculations.
This discussion may be of interest to those studying nuclear physics, particularly in the context of radioactive decay and the associated energy calculations.
JMP1961
To calculate the binding energy released when alpha decay converts radium 226, with atomic mass of 226.025, into radon 222, with atomic mass 222.01757, I understand that we subtract the atomic mass of radium 226 from the sum of the atomic masses of the radon 222 and the alpha particle, which is the helium nucleus (atomic mass 4.002603). My question involves the two electrons that are "left over" and I assume are contained in the radon atom after the transmutation. In other words, during the alpha decay, two protons and two neutrons are emitted as an He 4 nucleus. We are then left with 86 protons and 136 neutrons and to get radon 222. Where are the 88 electrons that radium 226 started with? Since a helium nucleus is emitted, I assume the electrons are in the radon, producing a negatively charged atom. So I would think that to calculate the binding energy, I would have to include the mass of the two extra electrons in addition to the atomic mass of radon. But this seems to give me an incorrect answer. Or is the book mistaken? or is 4.002603 the mass of the helium atom, rather than that of the alpha particle as reported. I am confused about these two electrons! How are they accounted for?
Where could they be?
If the only thing that has happened is the ejection of a He nucleus from the radium nucleus then, logically, what happened to the electrons?
Generally the atomic binding energies of the electrons are so small compared with the nuclear energies that we don't bother to include them.
The masses that you find in tables are always atomic masses (including enough electrons to make a neutral atom), not nuclear masses. The mass that you give for an alpha particle is actually for a neutral helium atom, so it includes the mass of two electrons.
For a nuclear decay, strictly speaking you should use nuclear masses when calculating the energy released, but it's OK to use atomic masses in alpha decay because the total number of "extra" electron masses is the same before and after so they cancel out. With beta+ and beta- decay you have to be more careful.
I remember alphas as the worst type of ionizing radiation because of the net positive charge. The 2 He 4 with a +2 charge. An alpha is so ionizing it can't make it through a sheet of paper. So it would reason that after the decay the ejected alpha would quickly strip the electrons from somewhere.
@JMP1961: any of this of any use?
We cannot help you if you don't answer questions.
The OP hasn't been here since he posted that question.
Has OP turned on email notifications?
  • · Replies 17 ·
