Magnetic field created by a solenoid
The discussion centers on calculating the magnetic field generated by a solenoid surrounding a long, straight, hollow plastic tube containing ionized liquid. The magnetic field on the axis of the tube is determined to be 0 T, as confirmed by multiple participants. However, an alternative approach considers the system as a dipole, leading to the formula B = (μ₀ / 2πd³)Nπr², where μ₀ is the permeability of free space, N is the number of loops per meter, and r is the radius of the tube. Participants debate the validity of this dipole approximation and the inclusion of the ionic current in the calculations.
  • Understanding of magnetic fields and solenoids
  • Familiarity with Biot-Savart Law
  • Knowledge of magnetic vector potential
  • Basic principles of electromagnetism
  • Study the Biot-Savart Law for calculating magnetic fields
  • Explore the concept of magnetic vector potential and its applications
  • Learn about dipole moments in electromagnetism
  • Investigate the effects of ionic currents on magnetic fields
Students and professionals in physics, electrical engineering, and anyone interested in understanding the behavior of magnetic fields in systems involving solenoids and ionized liquids.
Pepealej
Inside a very long, straight and hollow plastic tube (R << L) we have ionized liquid moving at a velocity v = 100 m/s. The net charge per unit volume is n = 106 electrons/m3. The radius of the tube is R = 10cm. Around the tube we have a solenoid, with n = 100 loops/m, through which circulates a current I = 2 A.
Estimate the magnetic field on the axis of the tube at a distance d >> L.
Book's answer
0 T or, considering the system as a dipole, [tex]B=\dfrac{\mu_0}{2\pi d^3}N\pi r^2[/tex]
My question
I understand how the magnetic field is 0 T but, how can I consider the system as a dipole to obtain the other answer?
Thanks in advance!
Pepealej said:
Book's answer
My question
Thanks in advance!
Well, we can all see B = 0. But their other answer (dipole) makes no sense since neither the ion nor the wire current I is included in their formula. Probably a typo, but ...
I would say:
Consider all the turns of the coil bunched together to form a single-turn loop with current = nLI. That makes using Biot-Savart easy along the axis & is justifiable by d >> L.
As for the ionic current, about all I could see is trying to compute the magnetic vector potential integral A, then B = del x A.
