How to add four arctangents efficiently
  • Thread starter Thread starter mgamito
The discussion focuses on efficiently computing the sum of four arctangents using the arctangent addition formula: \(\arctan(u) + \arctan(v) = \arctan\left(\frac{u + v}{1 - uv}\right) + \pi n\). The user, Manuel, proposes invoking this formula three times to minimize function calls, while addressing the challenge of tracking the integer \(n\) to ensure the result remains within the range \(0 \leq \alpha < 2\pi\). The solution involves managing the signs of the denominators in the formula and adjusting for any necessary \(\pi\) corrections.
  • Understanding of the arctangent addition formula
  • Familiarity with trigonometric functions and their properties
  • Basic knowledge of integer arithmetic and modular arithmetic
  • Experience with mathematical proofs or derivations
  • Research the properties of the arctangent function and its periodicity
  • Study the implications of tracking integer values in mathematical expressions
  • Explore advanced trigonometric identities and their applications
  • Learn about numerical methods for optimizing function calls in programming
Mathematicians, computer scientists, and software developers interested in optimizing trigonometric calculations and understanding advanced mathematical concepts related to arctangent functions.
mgamito
I need to compute the addition of four arctangents:
[itex]\alpha = \arctan(x_1) + \arctan(x_2) + \arctan(x_3) + \arctan(x_4)[/itex]
Rather than call four arctangent functions, I was thinking of using the arctangent addition formula:
[itex]\arctan(u) + \arctan(v) = \arctan(\frac{u + v}{1 - uv}) + \pi n[/itex], for some [itex]n \in N[/itex]
I could invoke the above property three times and I would only have to call the arctan function once. My problem is how to keep track of the integer [itex]n[/itex] throughout so that the result is correct.
My initial variables [itex]x_1[/itex] to [itex]x_4[/itex] are all positive so the result should be an angle [itex]0 \leq \alpha < 2\pi[/itex]. I suspect the answer lies in keeping track of the sign of the [itex]1 - uv[/itex] denominators and introducing some factor of [itex]\pi[/itex] correction if they go negative.
I'll work this through the weekend but I thought I would post this here in case someone figured this out already.
Thank you,
manuel
maybe this can help you
http://www.enotes.com/homework-help/evaluate-value-this-expression-arctan-1-3-arctan-1-251223
Thank you,
manuel
If ##\arctan(x_1) + \arctan(x_2) = \arctan(y_1) + \pi n_1## and ##\arctan(x_3) + \arctan(x_4) = \arctan(y_2) + \pi n_2,## we then have ##\sum_{i=1}^4 \arctan(x_i) = \arctan(y_1) + \arctan(y_2) + \pi (n_1 + n_2),## which has the form ##\arctan(z) + \pi (n_1 + n_2 + n_3).## Here,
[tex]z = \frac{y_1 + y_2}{1-y_1 y_2}.[/tex]
We might as well just say that ##n_1 + n_2 + n_3 = n,## an integer.
  • · Replies 21 ·
