Area Calculation for y = ||e^x - 1| - 1|
The discussion revolves around calculating the area between the positive x-axis, the y-axis, and the curve defined by the function y = ||e^x - 1| - 1|. Participants are exploring how to analyze the function across different intervals of x, particularly focusing on the behavior of the function for x < 0, 0 ≤ x ≤ ln(2), and x > ln(2).
  • Participants discuss how to split the function into cases based on the value of x, particularly questioning the behavior of the function in the interval 0 ≤ x ≤ ln(2). There is an exploration of the implications of the absolute value in the function and how it affects the area calculation.
Some participants have provided insights into the definition of absolute values and how to approach the piecewise nature of the function. There is ongoing exploration of the function's behavior across specified intervals, but no consensus has been reached on the final area calculation.
Participants are working within the constraints of the problem as posed, which includes the requirement to show the area calculation without directly providing a solution. The discussion reflects various interpretations of the function's behavior based on its definition.
phospho
Q. Show that the area between the positive x-axis, the y-axis and the curve [itex]y = ||e^x - 1| - 1|[/itex] is ln4 - 1
I've drawn the curve:
http://gyazo.com/cfd52af0f82e0e7d6b063681a73de45a
I notice for x < 0 (as I drew e^x to start out with, that's how I noticed it):
y = e^xfor x>ln(2) y = e^x - 2 (again, as I drew it before hand)
I can't seem to see what y will be for for 0≤x≤ln(2), as all my other notices are because I drew them beforehand.
Could anyone explain how I can split up y accordingly for x <0 for 0≤x≤ln(2) x > ln(2) ?
For 0≤x≤ln(2), which range does e^x cover? In particular, what is its smallest value? Based on that, can you get rid of the inner modulus? In the same way, you can get replace the outer modulus.
y = e^x
Use the definition of absolute value, twice.
[tex]|e^x-1| =<br /> \begin{cases}<br /> e^x-1 & \text{if } e^x \geq 1 \quad \text{i.e. } x\ge 0 \\ \\<br /> 1-e^x & \text{if } e^x < 1 \quad \text{i.e. } x < 0<br /> \end{cases}[/tex]
[tex]||e^x-1|-1| =<br /> \begin{cases}<br /> |e^x-1|-1 & \text{if } |e^x-1| \geq 1 \quad \text{i.e. } x\ge \ln(2) \\ \\<br /> 1-|e^x-1| & \text{if } |e^x-1| < 1 \quad \text{i.e. } x < \ln(2)<br /> \end{cases}[/tex]
So you want x < ln(2) which gives ##\displaystyle ||e^x-1|-1| =1-|e^x-1| \,,\ ## but also x > 0 which tells you that ##\displaystyle |e^x-1|=e^x-1 \ .##
Put those together.
thank you!
  • · Replies 18 ·
  • · Replies 20 ·
