Proving Convergence of Series: (a_n) and (a_{2n-1} + a_{2n})
The discussion revolves around proving the convergence of series involving a sequence (a_n). The original poster presents two parts: the first part requires proving that if the series of (a_n) converges, then the series of the sum of its even and odd indexed terms also converges. The second part involves proving the converse under the condition that (a_n) approaches zero.
  • Mixed
  • Participants explore the relationship between the convergence of the series R_n and the subsequences S_n and T_n. There is a discussion about whether the convergence of R_n implies the convergence of S_n or T_n, with some questioning the validity of this assumption.
  • In part (ii), there is an inquiry into how the terms R_{2n+1} and R_{2n} can differ if (a_n) approaches zero, suggesting a deeper exploration of the implications of convergence.
Participants are actively engaging with the problem, questioning assumptions and exploring the implications of their reasoning. Some have expressed agreement on certain points, particularly regarding the convergence of R_n not guaranteeing the convergence of S_n or T_n. There is an ongoing exploration of how the relationships between these series might lead to conclusions about convergence.
There is a noted complexity in the relationships between the series and their subsequences, with participants highlighting potential misunderstandings about convergence implications. The original poster has indicated a lack of clarity in their approach, particularly in part (ii), which remains a point of contention and exploration.
drawar
Let [itex](a_n)[/itex] be a sequence.
(i) Prove that if [itex]\sum\limits_{n = 1}^\infty {{a_n}}[/itex] converges, then [itex]\sum\limits_{n = 1}^\infty {\left( {{a_{2n - 1}} + {a_{2n}}} \right)}[/itex] also converges.
(ii) Prove that if [itex]\sum\limits_{n = 1}^\infty {\left( {{a_{2n - 1}} + {a_{2n}}} \right)}[/itex] converges and [itex]a_n \to 0[/itex], then [itex]\sum\limits_{n = 1}^\infty {{a_n}}[/itex] converges.
(i) Let [itex]{R_n} = \sum\limits_{k = 1}^n {{a_k}}[/itex], [itex]{S_n} = \sum\limits_{k = 1}^n {{a_{2k - 1}}}[/itex], and [itex]{T_n} = \sum\limits_{k = 1}^n {{a_{2k}}}[/itex]
Then [itex]{R_{2n}}={S_n}+{T_n}[/itex], since [itex]\sum\limits_{n = 1}^\infty {{a_n}}[/itex] converges, the sequence [itex](R_n)[/itex] converges, and so is the subsequence [itex](R_{2n})[/itex]. It follows that [itex]\sum\limits_{n = 1}^\infty {\left( {{a_{2n - 1}} + {a_{2n}}} \right)}[/itex].
(ii) Ok so I'm stuck on this part. I already have [itex](R_{2n})[/itex] converges and [itex](a_n)[/itex] is bounded, how can I go about proving that [itex](R_{n})[/itex] converges as well? Thank you!
The convergence of Rn does not guarantee the convergence of Sn or Tn, you cannot write it as sum like that.
The idea to use a sequence and subsequences is good, however.
(ii) how can R2n+1 deviate from R2n, if an->0?
I'm sorry I wasn't able to reply earlier.
For (i), I agree with you that the convergence of [itex]R_n[/itex] does not imply the convergence of [itex]S_n[/itex] or [itex]T_n[/itex] but it can imply that ([itex]S_n[/itex]+[itex]S_n[/itex]) converges right?
Btw, I think I may get your point for part (ii), let me just say what I'm thinking: Since [itex]R_{2n}[/itex] = [itex]R_{2n-1}[/itex]+[itex]a_{2n}[/itex], it can be deduced that [itex]R_{2n-1}[/itex] converges to the same limit as [itex]R_{2n}[/itex], as a result, [itex]R_{n}[/itex] converges.
If you replace the second S by a T (typo?), yes.
That was the idea I had in mind, indeed.
