Kernel and Range of a Linear Mapping
The discussion focuses on determining the kernel and range of the linear mapping T from P^{R} to P^{R}_{2}, defined by T(p(x)) = p(2) + p(1)x + p(0)x^{2}. The kernel consists of the polynomials p(x) such that T(p(x)) = 0, which occurs if and only if p(2) = p(1) = p(0) = 0, indicating that the kernel is the zero polynomial. The range of T is the entire set P^{R}_{2}, as the kernel contains only the zero vector, confirming that the mapping is surjective.
  • Understanding of linear mappings and their properties
  • Familiarity with polynomial spaces, specifically P^{R} and P^{R}_{2}
  • Knowledge of kernel and range concepts in linear algebra
  • Ability to interpret polynomial expressions and their evaluations
  • Study the properties of linear transformations in vector spaces
  • Learn about the Rank-Nullity Theorem and its implications
  • Explore examples of polynomial mappings and their kernels and ranges
  • Investigate the implications of surjectivity and injectivity in linear mappings
Students and educators in linear algebra, mathematicians focusing on functional analysis, and anyone studying polynomial mappings and their properties.
Smazmbazm
Find the kernel and range of the following linear mapping.
b) The mapping T from [itex]P^{R} to P^{R}_{2}[/itex] defined by
[itex]T(p(x)) = p(2) + p(1)x + p(0)x^{2}[/itex]
I'm not sure how to go about this one. Normally I would use the formula T(x) = A * v but in this case I don't know how to find A or v. Would be great if someone could point me in the right direction.
Thanks in advanced.
I assume you know that the kernel is the set mapped to 0. T(p(x))= 0 (for all x) if and only if p(2)= p(1)= p(0)= 0.
And the range is the entire set PR2. Do you see why?
Yes I know that the kernel is the set that is mapped to 0. I think I'm just having trouble with understanding what [itex]T(p(x)) = p(2) + p(1)x + p(0)x^{2}[/itex] actual means. It's a bit too general for me. What is [itex]p(x)[/itex]? Is that saying that the power representation for [itex]p(x)[/itex] is [itex]p(2) + p(1)x + p(0)x^{2}[/itex]? Or the mapping of the power series [itex]p(x)[/itex] from [itex]P^{R}[/itex] to [itex]P^{R}_{2}[/itex] results in [itex]p(2) + p(1)x + p(0)x{2}[/itex]
I think I understand why the range is the entire set [itex]P^{R}_{2}[/itex], because if the kernel only contains the zero vector then the range must contain everything else?
  • · Replies 24 ·
