Register to reply
Differentiation with physics
Share this thread:
JeffGlasgow
#1
May8-13, 02:03 AM
P: 5
A moving point has a position function (P) and is given by 2D quantities where the (Y) axis is affected by gravity (9.8m/s/s) and (t) is in seconds.
X(t)=4t cos θ and Y(t)= 4t sin (θ)-5t^2
If θ = Pi /3 find the speed in directions after 10 seconds
Find the angle where maximum X direction = maximum Y direction
Find the time for maximum x direction = maximum Y direction
Find the acceleration after 2 seconds
Does the acceleration vary against time?
Relevant equations/notes
Equations of linear motion.
9.8m/s/s can be rounded to 10m/s/s for simplicity.
2. Relevant equations
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
Suddenly, the sun is eerily quiet: Where did the sunspots go?
'Moral victories' might spare you from losing again
Mammoth and mastodon behavior was less roam, more stay at home
CompuChip
#2
May8-13, 02:43 AM
Sci Advisor
HW Helper
P: 4,300
Hi Jeff, welcome to PF!
We have put the template that you haven't used in your post for a reason :) Maybe you can tell us what the "equations of linear motion" you mention are. I'm sure you already have some idea which one(s) to use?
JeffGlasgow
#3
May8-13, 03:06 AM
P: 5
After a bit of research I'm under the impression I need to use the formulae
V= u + at
S = ut + 1/2 at^2
V^2 = u^2 + 2as
Also my error in that the position function should be (s) instead of (p)
CompuChip
#4
May8-13, 04:04 AM
Sci Advisor
HW Helper
P: 4,300
Those formulas only hold for motion with constant acceleration a.
In your topic title you said "Differentiation with physics".
What does differentiation have to do with position and velocity?
JeffGlasgow
#5
May8-13, 04:15 AM
P: 5
Our lecturer has just tried to make it relevant/more difficult due to the fact that we are doing an engineering course.
CompuChip
#6
May8-13, 05:00 AM
Sci Advisor
HW Helper
P: 4,300
Actually I just realised that the formulas you gave are applicable in this case, so I'm a bit confused now whether your lecturer wants you to use differentiation or not.
I'm tempted to advise you to try both ways, but let's go for the first one first, since you have found those formulas.
What you should remember for 2D problems is that you need to consider the X and Y directions separately. So looking at
S = ut + 1/2 at^2
what are the initial velocity ux and acceleration ax in the X-direction? How about the Y-direction (uy, ay)?
Then what can you say about the formulas vx, vy for the velocity ?
JeffGlasgow
#7
May8-13, 05:43 AM
P: 5
I have no idea where to start with this one, let me try and find some notes on this....
CompuChip
#8
May8-13, 06:39 AM
Sci Advisor
HW Helper
P: 4,300
Look at the t's in the formula. The general expression for S(t) you gave is (something) * t + (something) * tē.
Can you write the expression for X(t) and Y(t) in the same way? Then you can compare the "somethings" and you should be able to read off what u and (1/2)a are.
JeffGlasgow
#9
May9-13, 01:31 AM
P: 5
For the y I get
S(t) = ut + 1/2 a t^2
Y(t) = 4t sin θ -5t^2 therefore I think that u =4 and a=-10 but I'm not sure where the sin theta comes from
And for the x I get
X(t) = 4t cosθ Therefore I think that u =4 again but I have nothing for a?! And I'm unsure where cos is relevant?
Register to reply
Related Discussions
Computational Physics (Making programs for interpolation and differentiation) Advanced Physics Homework 0
When can you change the order of partial differentiation with total differentiation? Calculus & Beyond Homework 1
Problems understanding differentiation in physics Calculus 0
Solve by Implicit Differentiation or Partial Differentiation? Calculus & Beyond Homework 12
Differentiation with physics things! Introductory Physics Homework 2
