Orthogonal Complements of Linear Transformations with Matrix A
  • Thread starter Thread starter LosTacos
    Orthogonal
The discussion revolves around the relationship between the kernel of a linear transformation and the orthogonal complement of the row space of its associated matrix A. Participants are tasked with demonstrating that the kernel of the transformation is indeed the orthogonal complement of the row space.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the definitions of the kernel and orthogonal complement, questioning how these concepts relate to the row space of matrix A. There are attempts to apply the dimension theorem and clarify the implications of vectors in the row space and kernel.
Some participants have offered insights into the definitions and properties of the kernel and row space, while others express confusion about specific terms and relationships. There is an ongoing exploration of how to express vectors in terms of the linear transformation and the implications of these relationships.
Some participants note a lack of clarity regarding the definitions of certain terms, such as what constitutes the row space and kernel in this context. There are also references to potential misunderstandings about the nature of vectors in these spaces.
LosTacos
Let L: ℝn→ℝm be a linear transformation with matrix A ( with respect to the standard basis). Show that ker(L) is the orthogonal complement of the row space of A.
The ker(L) is the subset of all vectors of V that map to 0. The orthogonal complement of W is the set of all vectors x with property that xw= 0. Would we use the dimension theorem:
dim(ker(L)) = n - dim(range(L)) = n - dim(W) =dim(Wτ). Since Wτ is contained in ker(L).
*Wτ is orthogonal complement.
This seems way to obvious. The row space is the subset of all vectors that are linear combinations of rows of A. So the kernel of L is the subset of all vectors in V that map to 0. Then, the orthogonal complement is the set of vectors with the property that x ⋅ w = 0. So, I need to prove that the vector x in the orthogonal complement is the same vector in the row space?
Let's use W in a meaningful way since you haven't defined what W represents. Let W = ker(L).
The orthogonal complement of W is the set of all vectors x with property that x ##\cdot## w= 0, where w ##\in## W.
Now, assume that x is any vector in the row space of L. How can you write x, knowing what you know about L and its matrix representation?
If a is scalars, then ax1 + ax2 + ... + axk = 0
What does this equation mean? I have no idea what you're doing.
That was the linear combination of the row space. That was how I thought to write x in terms of L. And it's equal to 0 because it is the kernel.
There are several things wrong with this.
1. There are not k rows in the matrix, so it makes no sense to list them as x1, x2, ... , xk.
2. The row space is not in the kernel. Your goal in this problem is to show that the row space is the orthogonal complement of the kernel.
3. A vector in the kernel doesn't have to be 0.
Okay, given matrix A and vector x:
A⋅x = 0 means that wkx = 0 for ever row vector wk in R. Therefore, the orthogonal complement of row space is kernel.
Any old vector x? Is x in the row space of A or is it in the kernel of A?
I don't follow this. Ax = 0 means only that x is in the kernel of A. Why does it follow that wkx = 0? Neither wk or x has to be the zero vector.
