Understanding the Concept of Ray of Light and Diffraction at Small Apertures
  • Context: Undergrad
  • Thread starter Thread starter Yogesh_2010
    Light Ray
The discussion centers on the concept of diffraction in relation to light and small apertures. It establishes that diffraction occurs when the wavelength of light is comparable to the size of an obstacle, and when the wavelength approaches zero, diffraction becomes negligible. The conversation emphasizes that while diffraction is always present, its significance depends on the ratio of wavelength to aperture size. The importance of determining acceptable levels of diffraction for practical applications, such as optical telescopes and microwave reflector antennas, is also highlighted.
  • Understanding of basic wave optics concepts
  • Familiarity with the principles of diffraction
  • Knowledge of wavelength and aperture relationships
  • Awareness of optical resolution and diffraction limits
  • Research the principles of wave optics and their applications
  • Study the mathematical formulation of diffraction patterns
  • Explore the concept of diffraction limit in optical systems
  • Learn about the design considerations for microwave reflector antennas
Students of physics, optical engineers, and anyone interested in the behavior of light and its applications in technology.
Yogesh_2010
I can't get the concept why there is no diffraction when lambda tends to 0 even for extremely small aperture.please explain simply.
Science news on Phys.org
Diffraction is light bending around an obstacle. Roughly, the wavelength of light must be larger than the size of the obstacle for light to bend around the obstacle. So if the wavelength of light is just "infinitesimally" bigger than zero, it will not bend around any obstacle with a finite size.
A "ray" is a totally artificial concept which often works well when doing calculations to predict what waves will behave like.
To be strictly accurate - there is always some diffraction. Once you have decided how much diffraction is acceptable (e.g. how much energy appears in the sidelobes of a parabolic microwave reflector antenna or what resolution your optical telescope needs) you can determine the width of aperture you will need for a given wavelength.
The passage in that book is trying to put it in perspective. In the end, you are considering the ratio of wavelength to aperture. As the aperture gets less then so must the wavelength.
P.S. You presumably have read outside that particular passage in the book - concerning resolution and 'diffraction limit'.
