Why there is no work done when one is holding weight?
  • Context: High School
  • Thread starter Thread starter ZeinabSayed
    Weight Work Work done
The discussion revolves around the concept of work in physics, particularly addressing why no work is considered done when holding a weight or carrying a school bag. Participants explore the definitions of work, energy expenditure in muscles, and the implications of these concepts in both theoretical and practical contexts.
  • Some participants explain that work is defined as the product of force and displacement, and since there is no displacement when holding a weight, the work done is zero.
  • Others argue that while no mechanical work is done on the weight, energy is still expended by muscles, leading to fatigue.
  • A participant introduces the concept of different muscle types, suggesting that smooth muscles may exert force without significant energy loss compared to skeletal muscles.
  • There is a discussion about the analogy of a toy helicopter, illustrating that maintaining height does not necessarily involve work in the traditional sense, but energy may still be lost.
  • Some participants differentiate between work done "on" an object and work done "by" muscles, suggesting that these concepts have different implications.
  • Concerns are raised about the efficiency of muscles and whether they can maintain force without continuous energy input, leading to questions about the nature of work and energy conservation.
  • One participant suggests that microscopic work may occur in muscle fibers, but questions its relevance to the original question about macroscopic work.
  • Another participant challenges the idea that the energy expended by muscles can be equated with work done on the weight, emphasizing the need for clear definitions.
  • There are references to the movements of atoms in a table under a weight, questioning whether this could be considered work, but others clarify that such movements do not constitute work in the context of the discussion.
Participants express a mix of agreement and disagreement regarding the definitions and implications of work in this context. While some agree that no work is done when holding a weight, others challenge this notion by discussing energy expenditure and efficiency of muscles, indicating that the discussion remains unresolved.
Limitations in the discussion include varying interpretations of work, the distinction between macroscopic and microscopic work, and the efficiency of different muscle types. These factors contribute to the complexity of the topic without reaching a consensus.
ZeinabSayed
why there is no work done when one is holding weight?
there isno work done when moving while carrying a school bag?
That refers to technical meaning of the term work, which is product of component of force along the direction of displacement times displacement of the body. As you hold the weight, you exert a force on it, but there is no displacement, since the bag does not move, so the work is zero.
That does not mean that you do not lose energy - exerting force by skeletal muscles requires that they spend energy, and you will get tired. I think there are other kinds of muscles, which can exert force without such great exhaustion, perhaps like those of seashells.
The other kind is "smooth" muscle. (The 3rd, "cardiac", appears only in the heart, so is of no consequence here.) Any differences in exhaustion rates or efficiency are due to external influences such as leverage and oxygenation methods. That's getting off topic, though.
You can keep a toy helicopter at a certain height by leaving it on the table or letting it hover next to the table. Hovering needs energy from the helicopters batteries but the table isn't going to run out of juice. This shows that it is not fundamentally necessary to do work do keep something at a certain height, but depending on what holds it up some energy might be constantly lost. In the case of the hovering helicopter it continuously accelerates air particles and does work on them and the movement of the air eventually dissipates into heat. So the hovering helicopter wastes energy to heat, not to holding it up.
The problem is how the muscles work, they can't stay contracted for long periods of time without requiring extra energy. Also when walking you bounce up and down and your arm moves up and down when holding a weight. Skeletal muscles can't store elastic energy efficiently, so you have to do work while rising up. Smooth muscles are better at storing tension for longer periods of time without a lot of extra energy.
So the answer is basically that there is no work done on the weight or the schoolbag, but you still have to spend energy simply because skeletal muscles waste energy and aren't capable of doing it better.
Work done 'ON' is not the same as Work done 'BY'. It's all in the definition.
I am not sure what do you mean. Work done on X and work done by X have the same magnitude and opposite signs. In our case, they should both be zero...
Not really. The work done BY your muscles is not the work done ON the weight you lift. There is a small matter of efficiency, which can often be zero.
On what is this work done then?
I agree with Jano L. The muscles are doing no work here. The work "on" and "by" are the same thing, just with opposite signs.
The input to your muscles is [chemical] energy (not work), the output is mechanical work.
An analogy I like is that holding something and getting tired is similar (in basic physics, not in actual chemistry/on the molecular level) to tying a rubber band to the ceiling and suspending something heavy from it, then watching the rubber band slowly stretch and break.
You wouldn't accuse the rubber band of doing work on the object even though it experienced material fatigue and eventually broke (actually it does do a negative amount if it stretches before it breaks), so you shouldn't say that you are doing work when your muscles experience fatigue either.
You can't support the principle of Energy Conservation yet say there is no difference between what happens in the muscles (which metabolise food) and what happens to the stationary weight. That is unless you want a paradox in a most basic bit of Physics. The difference between your arm and a table top is that there are constant movements in the muscle fibres, there must be hysteresis involved in this movement. These give a force times distance inside the muscles - which resolves any paradox.
That is true, there may be microscopic work done on fibres, conserving or not conserving energy. However, don't you think this is irrelevant for the original question? As far as there is no macroscopic work, it is OK to say just there is no work, because that is what textbook rightly say and what the original question was about.
This question is hardly worth discussing unless there is an introduction of some apparent paradox, imo (it's just a matter of accepting the definition. The only reason there is some suggestion of actual work being done by muscles is because you get tired (whereas a table doesn't) so I think the microscopic events are highly relevant.
If you hung up a box on a string and the string broke, would you say "wow lots of work being done by that string, so much it broke!" If anything it did less work than a rope that didn't break and just held the object up the whole time
I think work was done when you lifted the weight from ground and this work is now stored as potential energy.work cannot be quantified if there is no displacement so its all about how we define work like if you appear for an exam it doesn't matter how hard you study if you don't secure minimum passing marks you won't pass same like this it doesn't matter how much force you exert if there is no displacement then no work.
table top
wouldn't all those atoms in the table moving in reaction to the force of an object "resting" on the table be the distance component of F*D?
What do you mean by "moving in reaction to"? They may be in thermal motion but, after the system has settled down, once it's been lifted, there won't be any motion due to the lifting action.
Are your muscles constantly twitching in a way that helps them to their job? I'm not sure, but either way you look at it, there is no paradox here: Your muscles are simply a zero efficiency machine.
I'm sure you can think of other devices that have an input of energy but no output of work.
Afaiaa, muscle fibres cannot just stay contracted. Other fibres need to take over in order to maintain a lift force. This involves a constant process of force times distance with successive parts of the muscles. Animals that need to stand for a long time will use the skeleton in an equilibrium position (straight legs etc). to reduce the muscle power needed. Some will even 'lock' in position.
I mentioned the concept of "efficiency" earlier on.
But they are just fighting each other and not actually making the book move, right? Or another way; even if the book is vibrating ever so slightly, it doesn't, over time, change its elevation. Zero work being done on the book. You asserted an apparent paradox in that. I see none.
I am not discussing antagonistic muscles here. They add yet another complication. I am discussing the fact that groups of muscle fibres regularly take over the load from fibres that are 'tired' after a brief time in tension.
I, personally, see no paradox either but the very existence of this thread implies that some people are unsettled by the apparent difference between the situations where muscles are supporting a load and when a fixed, inanimate object is doing the same thing. The simple rule for finding Work done, seems to fall down (the possibility of seeing a paradox where there isn't one). In neither case is work being done ON the book but the muscles are consuming energy and that needs a little explanation - the resolution is available if you allow for small distances of movement as muscle fibres tighten and relax. That's all.
I think others have answered that.
there is no work done when moving while carrying a school bag?
Walking is a form of falling. With each step you fall forwards onto a bent leg which you then straighten lifting yourself back to the starting position. This means your trunk is bobbing up and down. More on that here..
http://pathyoutake.blogspot.co.uk/2012/01/why-is-walking-falling.html
If your legs were ideal springs they would convert energy back and forth from Potential Energy to Kinetic Energy and back again as you bob up and down, there would be no losses. In that case carrying a school bag would not require additional energy1. However your legs aren't perfect ideal springs, they cannot convert all the KE gained as you fall forwards back to PE. Some is wasted as heat etc. Basically humans are inefficient. This means some energy is required to carry an additional load like a school bag.
Consider what happens when using a trolley with wheels to transport a bag. The wheels make the process of moving the bag more efficent despite the extra weight of the trolley.
1I'm ignoring other potential losses.
  • · Replies 48 ·
  • · Replies 24 ·
  • · Replies 55 ·
  • · Replies 27 ·
