Proper form of schrodinger's equation?
The discussion revolves around the proper form of Schrödinger's equation in quantum mechanics, specifically addressing the use of total versus partial derivatives in the context of time dependence of the wave function. Participants explore the implications of these notations within the framework of quantum mechanics, particularly in relation to the Dirac bra-ket notation and the Schrödinger picture.
  • One participant notes the distinction between total and partial derivatives, suggesting that the total derivative indicates implicit time dependence through other variables, while the partial derivative concerns only explicit time dependence.
  • Another participant argues that the first form (using total derivative) may be seen as sloppy notation, asserting that a wavefunction generally depends on both time and space, thus advocating for the use of partial derivatives.
  • A different viewpoint suggests that in the context of Dirac notation, time is treated as a mere parameter, which could justify the use of the total derivative symbol.
  • Another participant emphasizes that in the Schrödinger picture, the wave function is a function of time only, supporting the use of the total derivative and discussing the implications for the representation of observables and eigenvectors.
Participants express differing opinions on the appropriate notation for Schrödinger's equation, with no consensus reached on whether to use total or partial derivatives. The discussion remains unresolved regarding which form is generally correct.
Participants highlight the importance of distinguishing between abstract Hilbert-space objects and their representations with respect to a given basis, indicating that the choice of notation may depend on the specific context of the discussion.
unchained1978
I feel a bit silly asking this, but I've been working through some QM lately and there's one aspect of Schrödinger's equation that's puzzling me. I've typically understood the equation as [itex]i\hbar \frac{d|\psi\rangle}{dt}=\hat H |\psi\rangle[/itex], but I've also seen it written as [itex]i\hbar \frac{\partial |\psi\rangle}{\partial t}=\hat H|\psi\rangle[/itex]. The use of a partial derivative instead of a total derivative is what's got me. In most cases, I know it doesn't matter but I can imagine some where it would. The total derivative indicates that [itex]\psi[/itex] may not explicitly depend on time, but implicitly could through some other variable which is dependent on time. This evolution is generated by the Hamiltonian. In the other case, the partial derivative only concerns explicit time dependence, and hence this form only makes sense to me when there is an explicit [itex]t[/itex] showing up in the equations. Which form is generally correct?
The form is telling you something about the nature of the state vector isn't it?
The first is either sloppy notation of the state vector depends on time alone (i.e. not space).
In general, a wavefunction or vector will depend on time and space and so you should use the partial notation.
http://www.nyu.edu/classes/tuckerman/stat.mech/lectures/lecture_12/node5.html
Since you've written the SE in the Dirac bra/ket notation, and in the standard formulation time is a mere parameter, you can consider using the total derivative symbol d as correct, sind the SE is about time evolution of kets and nothing more.
Yes, one should really clearly say that in the bra-ket notation [itex]|\psi(t) \rangle[/itex] does not depend on position, momentum, or any other values of observables. It's (in the here used Schrödinger picture of the time evolution) a function of time only, and thus you should use the total differential.
The wave function is always the (generalized) scalar product of a (generalized) common eigenvector of a complete set of compatible observables (e.g., position). In the Schrödinger picture observables are represented by time-independent self-adjoint operators, and thus also the (generalized) eigenvectors are time-independent. Thus you have
[tex]\psi(t,\vec{x})=\langle \vec{x}|\psi(t).[/tex]
Then you have to use the partial derivative to write
[tex]\mathrm{i} \hbar \partial_t \psi(t,\vec{x}) = \langle \vec{x}|\mathrm{i} \hbar \mathrm{d}_t \psi(t) \rangle = \langle \vec{x} |\mathbf{H} \psi \rangle = \hat{H} \langle \vec{x}|\psi \rangle=\hat{H} \psi(t,\vec{x}).[/tex]
Here, [itex]\mathbf{H}[/itex] is the Hamilton operator in abstract Hilbert space and [itex]\hat{H}[/itex] in the position representation.
It is quite important to distinguish the abtract Hilbert-space objects from their representation wrt. to a given (generalized) basis!
  • · Replies 17 ·
