Path Integrals Harmonic Oscillator
The discussion centers on solving problem 3-12 from "Quantum Mechanics and Path Integrals" by Feynman and Hibbs, specifically regarding the wavefunction evolution of a harmonic oscillator. The initial wavefunction is given as ψ(x,0) = exp[-(mω/2h)(x-a)²]. The solution involves using the kernel K for a harmonic oscillator, defined as K=(mω/(2πihsin(ωτ)))^(1/2) * exp[(imω/(2h sin(ωτ)))((x_b² + x_a²)cos(ωτ) - 2x_bx_a)]. The integral form of the wavefunction evolution is confirmed to be ψ(x,t) = ∫K(x,t;x',0)ψ(x',0)dx', leading to a derived expression for ψ(x,τ).
  • Understanding of quantum mechanics principles, particularly wavefunctions.
  • Familiarity with path integrals and their applications in quantum mechanics.
  • Knowledge of harmonic oscillators and their mathematical representations.
  • Proficiency in performing Gaussian integrals and algebraic manipulations.
  • Study the derivation of the kernel for harmonic oscillators in quantum mechanics.
  • Learn about the properties and applications of Gaussian integrals in physics.
  • Explore the implications of wavefunction evolution in quantum mechanics.
  • Review problem-solving techniques for quantum mechanics problems involving path integrals.
Students of quantum mechanics, physicists specializing in theoretical physics, and anyone interested in the mathematical foundations of wavefunction evolution in quantum systems.
Wislan
Hi,
I am reading through the book "Quantum Mechanics and Path Integrals" by Feynman and Hibbs and am having a bit of trouble with problem 3-12. The question is (all Planck constants are the reduced Planck constant and all integrals are from -infinity to infinity):
The wavefunction for a harmonic oscillator is (at t=0): ψ(x,0) = exp[-[itex]\frac{mω}{2h}[/itex] (x-a)[itex]^{2}[/itex]]
then, using Eq.(3.42) (ψ(x[itex]_{b}[/itex],t[itex]_{b}[/itex])=∫K(x[itex]_{b}[/itex],t[itex]_{b}[/itex];x[itex]_{c}[/itex],t[itex]_{c}[/itex]) * ψ(x[itex]_{c}[/itex],t[itex]_{c}[/itex]) dx[itex]_{c}[/itex]) and the results of problem 3-8 (the Kernel for a harmonic oscillator K=([itex]\frac{mω}{2πihsin(ωτ)}[/itex])[itex]^{1/2}[/itex] * exp[[itex]\frac{imω}{2hsin(ωτ)}[/itex]((x[itex]_{b}[/itex][itex]^{2}[/itex] + x[itex]_{a}[/itex][itex]^{2}[/itex])cos(ωτ)-2x[itex]_{b}[/itex]x[itex]_{a}[/itex])]
show that
ψ(x,τ)=exp[-[itex]\frac{iωτ}{2}[/itex]-[itex]\frac{mω}{2h}[/itex](x[itex]^{2}[/itex]-2axe[itex]^{-iωτ}[/itex]+a[itex]^{2}[/itex]cos(ωτ)e[itex]^{-iωτ}[/itex])]
Now so far as I can tell, a solution is to multiply the wavefunction at time 0 by the kernel from x at t=0 to x at t=τ and then integrate over all x, however (unless I've made an algebra mistake which is always possible) this doesn't give the required answer. Any ideas?
Thanks,
Will
Yes, the evolution of the wavefunction is given by
$$ \psi(x,t) = \int_{-\infty}^\infty K(x,t;x',0) \psi(x',0) dx'.$$
This integral is of the form
$$ \begin{split}
\int_{-\infty}^\infty \exp{\left[ -A (x')^2 + B x' + C\right]} dx' &= \int_{-\infty}^\infty\exp{\left[ -A \left(x'-\frac{B}{2A}\right)^2 + C + \frac{B^2}{4A} \right]} dx'\\
& = \sqrt{\frac{\pi}{A}} \exp{\left[ C + \frac{B^2}{4A} \right]}. \end{split}$$
Hopefully some of this is familiar and you can figure out the algebra.
