At what point does gravity become incompatible with QM?
  • Context: Graduate
  • Thread starter Thread starter Cody Richeson
    Gravity Point Qm
The discussion centers on the relationship between gravity and quantum mechanics, particularly at the intersection of macroscopic and atomic scales. Participants explore whether gravity becomes incompatible with quantum mechanics at certain energy levels or scales, and the implications of this relationship for theoretical physics.
  • Some participants question whether there is a gradual transition where gravity "still sort of works" at the quantum level or if there is a definitive cutoff.
  • Others argue that gravity can be treated quantum mechanically below certain energy thresholds, specifically below 10^19 GeV, suggesting that general relativity and quantum mechanics can coexist under specific conditions.
  • One participant notes that gravity is often negligible at microscopic scales due to its relative weakness compared to other forces, making its quantum treatment unnecessary in many scenarios.
  • A later reply highlights that effective field theory allows for the combination of general relativity and quantum mechanics over a range of scales, but acknowledges that issues arise at extreme scales, indicating a need for a more complete theory.
  • Some participants reference Richard Feynman's perspective that quantum theory does not guarantee gravity must be quantized, suggesting the possibility of quantum mechanics failing at larger distances or for larger objects.
  • There is a correction regarding terminology, with one participant clarifying the spelling of "Planck" in relation to the Planck scale, indicating attention to detail in the discussion.
Participants express multiple competing views on the compatibility of gravity and quantum mechanics, with no consensus reached on whether gravity becomes incompatible with quantum mechanics at certain scales or energy levels.
Participants acknowledge limitations in current theories, particularly regarding the applicability of effective field theories and the challenges posed by extreme scales. The discussion reflects ongoing uncertainties in the field of quantum gravity.
Cody Richeson
Is there some fuzzy area between the macroscopic and atomic worlds where gravity "still sort of works," or is it a dramatic cut off? I never understood this whole idea that it suddenly stops making sense at the quantum level. Does it start making progressively more sense as you increase the scale?
Gravity doesn't just stop making sense at the quantum mechanical level. We have no problem treating gravity quantum mechanically below energies of 10^19 GeV or so. (This is 10^15 times higher than the energy scale reached by the LHC). Above that point, the math tells us that the simplest quantum mechanical version of general relativity stops being valid, so something new must take over--perhaps string theory. Note that string theory is itself a quantum mechanical theory.
The problem with gravity is not so much that it doesn't make sense, but that it just doesn't need to be treated quantum mechanically: It is (1) very very weak compared to other forces in the systems and (2) doesn't change much at microscopic scales. In most microscopic processes, pretending gravity doesn't exist is an effectively exact approximation, and if it is not, then treating it at the level of F = m*g certainly is. (That's not even taking into account the effects at classical mechanics level...)
Check out:
http://arxiv.org/pdf/gr-qc/9512024v1.pdf
http://arxiv.org/pdf/1209.3511v1.pdf
'One can find thousands of statements in the literature to the effect that “general relativity and quantum mechanics are incompatible”. These are completely outdated and no longer relevant. Effective field theory shows that general relativity and quantum mechanics work together perfectly normally over a range of scales and curvatures, including those relevant for the world that we see around us. However, effective field theories are only valid over some range of scales. General relativity certainly does have problematic issues at extreme scales. There are important problems which the effective field theory does not solve because they are beyond its range of validity. However, this means that the issue of quantum gravity is not what we thought it to be. Rather than a fundamental incompatibility of quantum mechanics and gravity, we are in the more familiar situation of needing a more complete theory beyond the range of their combined applicability. The usual marriage of general relativity and quantum mechanics is fine at ordinary energies, but we now seek to uncover the modifications that must be present in more extreme conditions. This is the modern view of the problem of quantum gravity, and it represents progress over the outdated view of the past.'
The short answer is about the plank scale.
The longer answer is gravity is not incompatible with QM - a perfectly valid quantum theory of gravity exists - it is just not renormalisable, which means a cutoff must be explicitly included, and the cutoff is about the plank scale. The difference between renormalisable and non-renormalisable theories is renormalisable theories have a magical property - what we observe does not depend on the cut-off. We know, QED for example, breaks down well before the plank scale so it really has a cutoff as well but it doesn't need to be explicitly included in the theory because of the magic property it has of renormalisability - the precise value of that cutoff doesn't matter. But the jig is up with gravity.
Thanks
Bill
audioloop said:
Quantum theory does not absolutely guarantee anything has to be quantized. However given a field Lagrangian the fact you can is very telling and allows theories to be developed and predictions made, which is what science is all about.
Feynman may be right, he may be wrong - exactly as it is with all speculation. What we need is a well developed alternate theory that makes predictions that can be tested. And that was pretty much Feynman all over - correspondence with experiment is his bottom line.
Thanks
Bill
bhobba said:
Quantum theory does not a[STRIKE]bsolutely[/STRIKE] guarantee anything has to be quantized.
Bill
Righttttttt !
  • · Replies 69 ·
9K
  • · Replies 45 ·
14K
  • · Replies 22 ·
  • · Replies 76 ·
  • · Replies 105 ·
17K
