Find f(2) of a Polynomial Function | R and f(2)=5
  • Thread starter Thread starter utkarshakash
    Value
The discussion revolves around a polynomial function f(x) that satisfies a specific functional equation involving two variables, x and y. The original poster states that f(2) equals 5 and seeks to find the value of f(f(2)). Participants explore the implications of the functional equation and the nature of polynomial functions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants attempt substitutions and explore the structure of the polynomial function. Questions arise about the meaning of a polynomial function and the implications of the given functional equation. Some suggest simplifying the equation through substitutions, while others analyze the relationships between coefficients and roots.
The discussion is active, with participants sharing various approaches and insights. Some have proposed specific substitutions to simplify the problem, while others are questioning the degree of the polynomial and the nature of its roots. There is an ongoing exploration of the implications of the functional equation, with no explicit consensus reached yet.
Participants note the importance of the condition f(2)=5 and how it relates to the functional equation. There is a recognition that the degree of the polynomial and the nature of its roots are critical to understanding the problem, but these aspects remain under discussion.
utkarshakash
If f(x) is a polynomial function satisfying 2+f(x)f(y)=f(x)+f(y)+f(xy), x,y belongs to R and if f(2)=5, then find the value of f(f(2))
The question clearly seeks the value of f(5). I put x=0 and y=2. Then
2+f(0)f(2)=f(0)+f(2)+f(0)
2+5f(0)=2f(0)+5
f(0)=1
Now I put x=0 and y=5
2+f(0)f(5)=f(0)+f(5)+f(0)
f(5)=f(5)
:confused:
f(x) is a polynomial function. What does it mean?
ehild
Consider a substitution f(x) = g(x) + c. Can you find a value of c that simplifies the equation?
ehild
Nothing special I can think of.
I'm going to second this suggestion
f(x) is a polynomial function, of form f(x)=a0+a1x+a2x2+a3x3+...
What relations do you get for the coefficients from the given equation and data?
ehild
What relations do you get for the coefficients from the given equation and data? ehild
I still don't know the degree of polynomial
Ok following your method I arrive at this
2+g(x)g(y)+(c-1){g(x)+g(y)}=3c-c2+g(xy)
Right, so what value of c will simplify that greatly?
That is you need to figure out. From the condition f(2)=5 you get a relation between f(y) and f(2y), and that can be fulfilled with polynomials of a certain degree.
ehild
The only number I can think of is 1
Right, so what equation do you get for g()? When you have that, suppose α is a root of g(x). What other root(s) can you then deduce?
I show my way as I think it is quite simple and straightforward.
From f(2)=5 follows: 2+5f(x)=5+f(x)+f(2x) ----> -3+4f(x)=f(2x)*
f(x) is a polynomial f(x)=a0+a1x+a2x2+...+akxk+...
Plug into * and compare the coefficients of powers of x on both sides
-3+4(a0+a1x+a2x2+...+akxk+...)=a0+2a1x+4a2x2+...+2kakxk+...-3+4a0=a0
4a1=2a1
4a2=4a2
4ak=2kak
What is the degree of the polynomial?
ehild
Ah, but mine is so elegant :wink:
Elegant and cute, but less obvious.
I must be dumb but still do not know your solution.:mad:
ehild
ehild
I saw it. g(x)g(y)=g(xy) means if x is root of g then xy must be a root of g for ANY y. Severely limits the choice of roots. I think this is little too subtle.
I reached here, but what after? f(x)=1+xh(x). But it is obvious as f(x) is polynomial, and f(0)=1 (obtained by the OP already). Find the possible root of h?
ehild
ehild said:
I reached here, but what after? f(x)=1+xh(x). Find the possible root of h?
ehild
I'm not sure what h is supposed to be here. But once you get to the post you quoted you say "ah, g(x) must be xk" and use f(2) = 5 to figure out what k is
I do not see that "ah":mad: Perhaps I stick to my version too much which gives the degree at once.
ehild
ehild
If α is a root of g(x) then so is every multiple of α. So α = 0, and g(x) = axk, some a, k. From the equation involving g, a = 1.
Why can not have g(x) other roots than zero? :mad:
ehild
ehild
If g(b) = 0, then
g(b)g(y) = g(by)
0 = g(by)
If b is not equal to zero, I can pick y to make b*y any arbitrary number, so g = 0 always. Therefore the only possible value b can be is zero
I awoke at last (it is 8 am here). So from g(b)=0 follows that b=0; then all b-s have to be zero if g(b)=0. Thanks :)
But my solution is also nice:wink:
ehild
ehild
Sure. One reason I like my solution is that it solves the functional equation in general. You only have to plug in the datapoints given at the end.
I have to admit that your solution is really elegant and cute :cool:
ehild
g(x)g(y)=g(xy). Ok I assume that g(α)=0. So g(α)g(y)=g(αy) => g(αy)=0. This means any multiple of α is a root of g(x). But how is this result useful to me?
A polynomial has only finitely many roots. So you can deduce the value of α.
Ok I think the value of α is 0.
Exactly. So, what is the general form of g(x), and thus, the general form of f(x)?
  • · Replies 23 ·
