What Does "W" Represent in Acid Number and Softening Point?
  • Thread starter Thread starter Rajini
    Acid
The discussion clarifies that the 'W' in acid number and softening point notation, such as 8W60 and 130W180 °C, is a misprint originating from a Japanese patent application. The correct interpretation is that 'W' should be read as a tilde (~), indicating a range, specifically 8~30 for acid number. This correction is crucial for accurate understanding and application in resin specifications.
  • Understanding of resin chemistry and specifications
  • Familiarity with acid number and softening point terminology
  • Knowledge of patent documentation and nomenclature
  • Basic skills in interpreting technical documents
  • Research the significance of acid number in resin applications
  • Explore the implications of softening point on material performance
  • Investigate common misprints in technical documentation
  • Learn about Japanese patent application formats and terminology
Chemists, materials scientists, and professionals involved in resin formulation and quality control will benefit from this discussion, particularly those interpreting technical specifications and patents.
Rajini
Dear PF users,
We know what is meant by acid number and softening point for resins.
If it is mentioned as acid number is 8W60 and softening point is 130W180 °C, I am just confused what about 'W' in between those numbers..
Thanks for your reply.
Regards, Rajini.
Chemistry news on Phys.org
Is that nomenclature coming from your resin supplier? If yes, which one? Could the 'w' be a misprint perhaps? It might have been meant to be a hyphen, for example.
Hi Chemistree,
Yes, it is a misprint of some Japanese patent application. 8W30 should be read as 8~30 (8 to 30). When look into PDF file my doubt got cleared.
Thanks, Rajini.
  • · Replies 19 ·
11K
