Particle in magnetic field, classical and quantum view
The discussion centers on the relationship between classical and quantum descriptions of an electron in a magnetic field, exploring concepts such as circular motion, energy quantization, and the nature of orbits in the context of both frameworks.
  • One participant seeks to understand how classical circular motion of an electron in a magnetic field relates to its quantum description, particularly regarding orbits around magnetic field lines.
  • Another participant suggests that the expectation value of the radius for energy eigenstates is quantized, implying that these eigenstates represent "orbits" around the field lines.
  • A participant questions the derivation of the expression for the radius and expresses confusion over interpreting the relevant equations.
  • It is proposed that the expectation value of the radius should align with the classical radius for the same energy, with potential small corrections, and suggests solving the modified Schrödinger equation for a precise answer.
  • A participant notes the Hamiltonian for a particle in a magnetic field and discusses the non-commuting nature of momentum components, leading to a conclusion that the particle exhibits circular motion.
Participants express varying levels of understanding and interpretation regarding the quantization of radius and the relationship between classical and quantum descriptions. There is no consensus on the clarity of the quantum picture or the specific derivation of the radius.
Participants mention the need for further calculations and references to literature for a deeper understanding, indicating that the discussion may be limited by the participants' current knowledge and the complexity of the equations involved.
Nemanja989
Hi, I am trying to understand quantum description of electron in B field. What I am looking for is how to relate quantum and classical view?
If in classical treatment electron comes in homogeneous B field, it will go in circular motion around magnetic field lines, with radius R.
From quantum view, we get LHO and quantization of energy. From equation for energy we see that only in z direction (direction along B field) we have dispersion relation for a free electron. That is fine with classical result.
What I cannot see from quantum description, are there orbits around magnetic field lines. Did anyone thought about this, and is there some clear picture about this view?
If electrons are orbiting around B lines, I suppose that radius is quantized? Am I right or wrong?
For energy eigenstates, the expectation value of the radius is quantized, indeed. Those eigenstates are "orbits" around field lines.
Thank you for your reply. But I would like to ask you from where you see expression for the radius? I was looking for that, but probably I cannot interpret equations in right way :(
The expectation value should be the same as the classical radius for the same energy, maybe with a small correction term. You would have to solve the modified Schroedinger equation (with the B-field in the momentum term) and evaluate this to get an exact answer. Alternatively, look for books where this has been done before.
Ok, thanks.. On our QM course professor did not give us any physical picture while lecturing quantum LHO (and e in B), and therefore I was a little bit confused. I will to all the calculations.
Thanks once again :)
The Hamiltonian for a particle in a B field is H = (1/2m) p2 where p is the canonical momentum, p = P - eA/c.
Unlike the mechanical momentum, the components of p do not commute: [pi, pj] = (ieħ/c) εijkBk. Specializing to a uniform B field in the z direction, [px, py] = iħm ω where ω = eB/mc. Also [px, H] = iħω py, [py, H] = - iħω px.
Thus defining p± = px ± ipy,
[p±, H] = ± ħω p±
[p+, p-] = 2 ħmω
Normalized correctly, p± satisfy the same commutation relations as the raising and lowering operators for the simple harmonic oscillator.
But note that this oscillation is not between x and p as it is for the SHO, it's between px and py. Which suggests that the particle is following a circular orbit.
  • · Replies 39 ·
  • · Replies 19 ·
  • · Replies 33 ·
  • · Replies 36 ·
10K
